Question about Carrier Heating & Cooling
Hello,i have a problem. in the process of removing an expantion valve the distributer was damaged ,at the head,there telling me i cant get a distributer head with the tubes atached.that i need to buy a new coil is there any way to get the distributer allready assembeled
  • 107 Answers
You will need a new coil unfortunately.
Posted on Aug 25, 2010
Hello. I have a problem with my 2001 kia carnival. The top 2 pulleys are lining up but the problem I have is that the crankshaft has lost its mark and I am unsure how to line it up now?
GO TO YOUR #1 piston remove plug take off valve cover, turn engine over until both valves over #1 cylinder are closed. NO TENSION ON VALVE SPRINGS BOTH ROCKER ARMS A LITTLE LOOSE BY HAND NO TENTION IS IMPORTANT HERE..THATS WHY BY HAND TURN AND LOOK AT SAME TIME TO GET IT EXCACT.Stop turning engine the #1 piston should be close to surface or head. Your engine now is very close to TDC.....GOOD LUCK..AND IF YOU HAVE A DISTRIBUTER REMOVE CAP NOTEING WHERE THE #1 PLUG WIRE IS LOCATED AND THE ROUTER UNDER NEATH SHOULD BE POINTING RITE AT # 1 CYLINDER AND WIRE ON CAP..ESPECIALLY CAP..IF NOT TIMINGS OFF..IT CAN BE A 180 OUT AND STILL RUN..BUT NOT CORRECT..IF THIS IS A DUAL OVER HEAD CAM ENGINE FORGET ALL I SAID AND TAKE IT TO A MECHANIC..I CANT EXPLAIN THAT PROCESS..TO DETAILED..GOOD LUCK
Apr 01, 2015 | Kia Carnival Cars & Trucks
Were is the expantion of A/C located in chavy cavalier 2003
there won't be an expansion valve their will be an orphis located in the discharge tube
Aug 29, 2012 | 2002 Chevrolet Cavalier Coupe
Ac leak in the evaporator area
The most common area of refridgrent leaks is the front seal of the AC compressor, the evaporator is the least likely.
Jun 08, 2017 | 2005 Toyota Tacoma
Misfire cylinder 4 dodge 1500 5.7L hemi
Check compression. If its nill or low, pull a plug and look for raw fuel. Try to look at the top of the piston for impact marks. The valve guide comes loose and the valve will hit the piston causing valve damage. Most instances won't damage the piston to a point of necessitating replacement, but will require removal of the head for a valve job or replacement of the head due to valve damage or chipping of the cylinder head at the valve seat. A reman head isn't much more than the machine shop will charge for a valve job. 6 hour job plus gaskets. Don't let anyone tell you it needs an engine without substantial proof.
Jan 08, 2012 | 2004 Dodge Ram 1500
Broken crank shaft the mechanic said he wont be able to know if valves are bent until he puts it back together of course he said the valves are bent. How difficult is it to replace valves?
Find another mechanic. you got ripped off. A broken crank does not mean you cant check the valves. Called a leak down test. This engine should have been replaced. And probably still should. Your talking about a $1500.00 job.
Aug 10, 2011 | 2000 Chrysler Sebring
Got ticking noise coming from the back valve cover right under the trottle body when the engine is about 1,500 to 2,000 rpm and then goes away. What it could be?
You gotta remove the valve cover (its easy) and take a look at your valves to see if a spring has broken
or other part (e.g. rocker arm) is damaged - before the head is irreparably damaged and needs to be replaced - which is what most garages will tell you to do with a pinging/ticking head.
While you've removed the valve cover, consider replacing the valve cover gasket, which is a common
place for an oil leak to develop.
Jun 13, 2011 | 1996 Nissan Maxima
BROKEN TIMING BELT- Testing valves, etc for damage- (1997 NEON) I have installed the larger DOHC engine in this car about a year ago. Recently, the timing belt broke. It IS an intermittent engine. I...
Think about this for a moment....You already know you have a few bent valves. Valves are serviced by removing the cylinder head. That single fact tells you that the head needs to come off to do the repair.
Once you remove the head, you will be more able to inspect the remaining valves and piston tops, then with that information, decide if you can rebuild it. A compression test requires spinning the engine and risking further damage.
Jun 09, 2011 | 1997 Plymouth Neon
My timing belt broke how do i tell if their is endgin damage
According to Gates chart, you engine is an 'interference engine' meaning that the valves and pistons can collide. The belt change interval is 60,000 miles/100,000 km.
I had an engine that could interfere but lucked out and no damage occurred which I established only be removing the cylinder head.
I would not install a new belt without pulling the head and inspecting for damage, otherwise even greater damage may occur if one or more valves are bent or have broken the valve stems. If the head is removed, make sure that it and the block are checked for flatness otherwise a replaced head gasket (must be done if head is removed) may fail prematurely. If either is not flat, they must be resurfaced before reassembly.
Apr 08, 2011 | 2003 Hyundai Tiburon
Match up Carrier equipment
carrier did sell some systems with R407c as a quick fix to gov regulations for about 2 yrs. R407c is a blend . and is treated like R410a except R407c pressures are more simular to R22. being that the pressures run the same the system should work with out changing any parts that being said if the evaporator has been used for R22 the oil residue wiil give you problems ifit is a new unit you would be ok.
Jan 08, 2009 | Carrier 38CKC042 Air Conditioner
I need a new engine head
Not a recall. Find a head in the junkyard and have the valves reground.
Jan 05, 2009 | 2004 Audi A4
Heating & Cooling Logo
20 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
