HP Pavilion dv6000
Before I buy any parts - I need to know which parts. My laptop does not switch on even if the mains is plugged on. This has happen before but after twiddling with battery it switches on
  • 1 more comment
  • Laiman May 05, 2008
    yes the blue light is there
    there are no beeps
    There is the blue light from tha main adaptor, do you think it is worth buying a new battery.
  • 13,433 Answers
Hello Laiman
I would recommend you get your hands on a laptop minipci diagnostic card as it can tell you what is the problem.
Here is one
http://cgi.ebay.com/New-MiniPCI-Diagnostic-Laptop-Computer-Defect-POST-Card_W0QQitemZ380023032837QQihZ025QQcategoryZ1244QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The card is inserted into the minipci slot in the bottom of the laptop, there is possibly a wireless lan card in place so you would have to remove it first.
If your not intrested in that, tell me do you hear any beeps from the pc? if you see and hear noting then its possible the motherboard would need to be replaced 100-1000usd
also its possible there is a loose connection or faulty ac adapter. try with another adapter or another battery if possible.
If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
Posted on May 05, 2008
  • Ekse May 05, 2008
    Do you see the power light on the laptop while its connected to the ac adapter?
  • Ekse May 05, 2008
    No don't buy a battery.
    its useless to you if there is a seriour problem with the motherboard.
    Id suggest you take the laptop to a professional to be tester or buy a tester to see whats wrong with it.
    Could be mainboard, cpu, vga or memory problem. No beeps.. cant say what is wrong.
Philips TV freezes or turns on/off continuously
please check on mains chord and plug or even better the plug itself by connecting another lamp to see it flickers meaning something wrong with the AC line in.
1.either replace mains power chord
2. also see solder connections inside TV that is if you know something about mains take care to switch of mains and disconnecting main chord
happy hunting
Sep 12, 2015 | Philips Televison & Video
Simpson eziset 550
good day,
the problem of your unit is the main pcb board if electronic type or the mechanical switch problem, but same cause its burnt part and its hard to check. call the technician for your safety and to not waste your money to buy some part if you dont know what the main reason why its burnt part
Nov 02, 2013 | Washing Machines
My laptop is not switch on even i plugged in....
I was using my laptop just a few hours ago browsing Facebook, when my laptop just completely shut off instantly, and then wouldn't turn back on... the laptop was plugged in at the time.
The laptop shows no lights or anything indicating the laptop it plugged in like usual, and nothing at all happens when I press the power button.
I have tried plugging the laptop out, taking the battery out and holding the power button for 1 minute and plugging back in with no luck.
Also I should add that for about 2 months now ever since I installed Windows 7 I have been getting the message "Consider replacing your battery" and the battery hasn't been holding much of a charge, maybe 25-30 mins. But I don't know if this is the problem because shouldn't the laptop work as normal when plugged in?
Sep 07, 2013 | Lifetime Toshiba Satellite U505S2965...
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Dc-in jack broken on my acer extensa. Can this be fixed?
Yes! Is the straight forward answer to that. You can source the jack on line and fix it yourself if you know how to wield a soldering iron and screw driver. Failing that, a computer repair shop can do it easily, but it will cost (of course!)
You don't say what model it is, but have a look around here for hints on how to dis-assemble your unit; http://repair4laptop.org/disassembly_acer.html
Jan 12, 2010 | Computers & Internet
Packard Bell Laptop goes flat even when plugged into the mains su
Are you sure that the power adaptor is working? Does it have any light on the adapter box that informs about it's operation?
What usually happens is that the cable going from the adapter to the laptop gets crackled from repetitive bending, either at the plug, or at the box inlet. Inspect if the cable is intact, and if possible, checks if there's a required DC voltage on the plug.
Perhaps you might need a new adapter for your laptop.
Dec 07, 2009 | Computers & Internet
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
May 30, 2008 | Acer TravelMate 2300 Notebook
Ds lite console keeps switching of then won't start again
Theres an internal error you will need to get it sent off for repair
Apr 19, 2008 | Nintendo DS Lite Console
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
