Question about Dishwashers
I have an AEG Favorit Sensorlogic Turbodry and it wony start. You switch it on and the onlycycle button that lets you press it is AUTO but it does nothing and then after a couple of minutes it just starts beeping
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Could be the drain pump thats blocked /jammed or faulty. the first 2mins the pump is energised if it does not run the electronics sense this and cancel the prog. Also similar if no water supply or if water valve faulty after 5mins. Dont think it will be aqua flood control as pump would run and alarm sound instantly. more mysterious problems can be heater down to earth. and lastly the electronics itself.check the others first though.
Posted on Aug 24, 2010
In which way can i reset my dw AEG favorit F 86050 vi?
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
Apr 26, 2009 | AEG 24 in. Favorit 60820W Free-standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
399 people viewed this question
Top Dishwashers Experts
