Question about Seagate 750GB FREEAGENT SATA/USB 2.0 750 GB Hard Drive
On my hard drive there is a flashing light. My computer say i must turn on the hard drive, what should i do
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Posted on Aug 25, 2010
My drive is almost fill a 4g now when i plug it in it is not reading any of the stored files.
Hello there!
USB flash drives in general, are wonderful little tools that allow people to store a relatively a large amount of data in a compact and portable interface that is extremely easy to use at all. The downside of storing lots of critical data on a USB flash drive, however, is that they're fairly susceptible to damage and that you can lose all of your information immediately if something goes wrong. When troubleshooting a USB flash drive, there are several key things to check and to remember that will help you to determine whether your flash drive is destroyed or not.
1. Look and see whether or not your USB flash drive's indicator lights are activated when it is plugged in to your computer's USB port. The vast majority of USB flash drives have small LED lights located somewhere on them that flash intermittently when they're hooked up to a computer. If your light does not turn on, then it's either not plugged in properly or is damaged and likely not repairable.
2. Make sure to download and install the right driver software for your USB flash drive.
3. Try your USB flash drive on more than one computer before giving up on it altogether. If it works on another computer, then the problem is likely with your computer hardware or software, not with the USB flash drive.
4. If you cannot restore your files, you may use a third party software to recover them.
Regards,
fossildude
Mar 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I insert the flashdrive into my computer the
Try the flash drive in another computer to see if it works.
If it doesn't work, format the flash drive, you will lose the data stored on the flash drive.
If you want to recover the data on this flash drive, this program may help :-
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Sep 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i plug the hard drive in, a blue light flashes but the dard drive doesn't turn on.
First check your usb port of computer and usb csable are working fine.
Then go to my computer proeprty then hardware then device manager then uninstall all usb drivers then restart the computer then check
Aug 20, 2009 | Western Digital Elements powered by WD 320...
Gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
Jun 23, 2009 | Gateway 500GR PC Desktop
Usb 8 gb doesn't show on my pc, light flickers and stays on
Probably the flash drive is not getting enough power from the computer. Try to connect the flash drive to the USB port located at the back of the tower.
Jun 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Blue light flashed on the portable hard drive for a couple seconds.How do I know if all files were transfered? Nothing on screen showed up? I have a HP laptop.
If your portable hard drive was set up as the "H" drive, go to My Computer (in Windows XP), or Computer (in VISTA), select your "H" drive and view your files (if there).
Jun 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Seagate 750GB FREEAGENT SATA/USB 2.0 750 GB Hard Drive Logo
114 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
