Question about kawasaki Full Suspension Mountain Bike Men
I have a club car utility with kawasaki fe350d engine. Cooling vains were plugged, have been cleaned. Half hr or so of running sounds like the valves are tapping. Runs good but the noise is of concern. Solution?
  • 65 Answers
SOURCE: timing problem
hi idont believe that you have piston to valve problems as the valves would simply bend, this would then reduce your compression and your m/c would not run correctly .
wot you may be suffering from is just large valve clearance or worn camshaft and or valve gear,however this must be investigated further
hope this is of help ian
Posted on Dec 31, 2008
  • 124 Answers
SOURCE: 2002 drifter 800. Bike starts and runs good for
Sounds like you have a fuel delivery problem. First check to see if there is a inline filter from the fuel tank to the carburators that is partially plugged. If not, you will have to remove the fuel valve from the fuel tank and clean the screens on the fuel pick-up tubes. The only other thing that would cause a fuel delivery problem would be the vacuum line from the carburators to the fuel valve has a split causing insufficient vacuum to open the fuel valve.
Posted on Nov 16, 2009
  • 110 Answers
SOURCE: bike runs good but after about 45 min of riding it
hello there:
try turning you're spit **** to reserve and see if still does the same thing if so you're more than likely looking at needing to replace the vale adjusting pads this will cause the problem of not running right i had same problem with a 1998 Kawasaki after the adjusting pads were flat-end out... so this should solve the problem best of luck to you sincerely D Jones
Posted on May 30, 2010
19ken55
  • 426 Answers
SOURCE: 1986 kawasaki zl600 idles good
Check compression. It may be tired.
Posted on Feb 03, 2011
djkoda
  • 55 Answers
SOURCE: 1981 kawasaki 440LTD. Engine oil light stays on.
Well if your oil light is staying lit, but your oil pressure is good and you cant find any problems with the actual oiling of the bike, then this sounds basically like either A.Your sending unit is bad or B. You have a ground in your oil sending unit circuit somewhere. You could always replace the sending unit first to save time shooting the wiring harness.if you replace the unit and the light is still on, then you have a wire touching in the circuit between the sending unit and the warning light. I have an 81 KZ750 and my oil sending unit only has one wire going from it to the warning light and the color of it is Blue with a Red Stripe.I am not sure if yours has the same wiring colors though.
Posted on Aug 02, 2011
Why does my engine run perfect for 5 minutes then rough?
Sounds like a fuel starvation issue. Does the choke stay open? The motor could be overheating, too. Make sure the heat sink blades are free of junk.
Jul 22, 2014 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Oil leakage
steam clean engine and run engine for half an hr and you shuold see where the oil is leeking from then replace any gaskets pipes ect
Dec 31, 2013 | 2003 Mitsubishi Montero
Car will start and run, then when I shut it off it wont start back up after sitting for a half hr of so
Check the catalytic converter it is probably plugged and not allowing fuel into the cyl. due to putting back pressure on the engine. If possible pull the 02 sensor out of the exhaust ahead of the catalytic converter and if it is plugged you should have the car to run. It will run rough but if it starts it is the problem.
May 28, 2017 | 1989 Chevrolet Celebrity
Motor shuts down after running for about half hr,after cooling down about one hr it will restart.
BAD RUN CAPACITOR . HAVE IT CHECKED, OR JUST REPLACE IT. TEST IS BEST, IT COULD BE THE MOTOR IS SHORTED, OR YOU HAVE INSTALLED TO SMALL OF A MOTOR ON YOUR IMPELLER, MOTOR HP + SERVICE FACTOR = TOTAL HP ! A COMMON PROBLEM WITH HAYWARD NORTHSTAR.. SAY THE MOTOR SAYS 1 hp AND HAS A 1.65 SF . thats a 1.65 hp MOTOR .. WELCOME TO MY WORLD.. JAY THE POOL PULP REPAIR GUY IN LONGWOOD FL.. VOTE YES IF I WAS OF HELP.. OH AND ONE MORE THING RESTRICTED FLOW, TAKE OUT THE FILTER AND RUN IT WITHOUT. YOU MUST HAVE A WORKING PRESSURE GAUGE ! BE "WELL UNDER" 30 PSI WEN CLEAN
Jun 08, 2011 | Hayward Pool & Spa
I have a kawasaki 300 byou 1990 moled 4X4 that i put a carberator kit in but just doesn't run right spits and sputters when i give it gas it will idle ok sometimes. drained all gas and cleaned out good....
It sounds like it is running too rich (too much fuel). First, make sure the air filter is clean and that there are no intake leaks between the carburetor and the engine. Also, try a new spark plug (they can go bad without warning). Then, with the engine at normal operating temperature and idling, adjust the idle mixture screw to attain the highest idle speed. After this, set the idle to the correct speed using the idle speed adjustment screw.
Test ride. If it still spits and sputters at half to full throttle, then you will need to get a smaller main jet - or go to a less restrictive air filter, such as one by K&N.
Finally, I am not sure what prompted you to put a carburetor kit in, but if the bike had been sitting for any lenght of time (more than 6 months) make sure the carb isn't plugged up.
Nov 20, 2009 | 2003 kawasaki KLR 250
Nov 16, 2009 | 2002 kawasaki VN 800 Vulcan Drifter
Car has half tank of gas acts like its run out of gas until more
is there a engine light on? take the gas cap of and see if it does better you might have a plugged vent
Oct 28, 2009 | 1997 Dodge Ram 1500 Club Cab
The bike will run with a push start, but the electric starter has a hard time starting the engine. It also will not sit in idle. It just bogs down and dies. I've cleaned the carbs and run an engine cleaner...
Take a compression test on the cylinder.
Check the spark plug and its gap.
Check the condition of the spark plug, is it whitish, brownish or blackish?
If its whitish means the engine is running 'lean', if it's brownish....means runs ok, blackish means its running too rich ..thus fouling up the spark plug.
Check the valve clearance too.
Since its not idling....check the intake rubber for leaks.
As also you have cleaned the carburator, recheck the jets fittings, blow the primary jet, recheck the float level if its correct.
You might too, have to reset the air-mixture screw. Its all the way in , being careful not to reach it too tight in it may damage the screw, thn trun it outwards 2 and a half turns or so....keeping the idling screw a little high and as you thn hear the engine sounding proper reset the idling to the required rpm.
Hope this helps! Good Luck.
Jul 14, 2009 | 2003 kawasaki KLX 125
Kawasaki gt550 won't start from cold! even with choke!!
when you get the bike started you need to adjust the pilot air screw. here's how= turn in clock wise until engine falters(mark that spot with a pin)then out counterclock wise until the engine falters(mark that spot also) then put the screw in half amount adjustment of the two marks.that will take care of if it is to lean or to rich.make sure the engine is good and warm before doing so.
Apr 23, 2009 | 1992 kawasaki GT 750
P1556Turbocharger Boost Sensor (A) Circ Control limit not reached - Car is Audi A4 1.9tdi Year 2000 Model B5 Changed all air hose and still showing the same fault. Also replaced the sensor, but continues...
possible air flow meter,or vains sticking in turbo (if its a pd engine)check your air flow rate on vag tool,should be between 12 - 14 kg/hr or 2-4 g/s
Dec 29, 2008 | 2000 Audi A4
kawasaki Full Suspension Mountain Bike Men Logo
109 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
