Using a TDK Double Layer Disc in an LG combo VCR/ DVD recorder trying to copy from a pre recorded tape on SP speed and the disc stops at 2hours and ejects disc. When putting the disc back in the recorder it tells me that it does not recognise this disc. I have used another disc of a different brand without any problems. What if anything am I doing wrong?
  • 563 Answers
Hi ohdeer
I've had a similar problem with a LG DVD / VCR that was hooked up to a voice recording system.
We found that it was the format of the DVD i.e. DVDR+ or DVDR- disks.
Also it is much better for recording purposes from Video to DVD to switch the machine over to LP mode.
Hope this is of help !
Thanks for using Fixya.
Posted on May 05, 2008
  • 13,433 Answers
Hello ohdeer
Could be that the disc is not compatible with the dvd player. Theres not much I can think of if it works fine with another brand?
If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Aug 10, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
