Question about Xerox Workcentre M24 Color Copier
I have just bought an M24 and I need to know how to enter service mode so I can set the TCP/ip settings. Can you help
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 38 Answers
Just press system administrator key than type pasword(mostly 11111)
Posted on Sep 10, 2012
    President:
  • 2,072 Answers
Should be either access then 1111 or 11111.
Posted on Aug 24, 2010
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
When setting up a USB wireless adapter for wireless access on a second PC to the internet, which IP address am I supposed to enter? I have a cable modem, so do I put in the IP for the Ethernet adapter or...
ur gateway IP for the Router will be something like this (this is only for your guidance, check ur service provider for the actual IP address digits to be entered insted of the XXX mentioned here by me
Gateway IP address
XXX.XXX.1.1
your machine IP will be like this
XXX.XXX.1.3 for machine 1
XXX.XXX.1.5 for machine 2
Subnet Mask will be
255.255.255.0 or something else, check ur service provider
these settings have to be done in the TCP/IP setting of each machine
in machine one the TCP/IP setting will have
XXX.XXX.1.3 in the IP address field
and in machine two it will be
XXX.XXX.1.5
DNS address will be your service provider's server IP address....
XXX.XXX.XXX.XX
XXX.XX.XXX.XX
Note: XXX.XXX to be replaced with numeric digits based on your service provider's settings.
check with your service provider for the gateway IP address, and IP address
Dec 14, 2009 | Microsoft Broadband Networking MN-500...
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
Computer will not recognize drivers for ethernet card
Was this all working just fine prior to reinstalling the system on the computer. I want to first rule out any hardware connection problem. When you check the ethernet adaptor in the device manager, does any punctuation mark appear next to it to indicate a driver problem? if not, your problem is not driver -related, but rather settings. If the LAN connection appears in the manage connections or the connection wizard, you may only need to enter the correct settings to make this work. Make sure TCP/IP is enabled for the device, and that DHCP is enabled in the TCP/IP settings. The exception to this is if the modem does not assign an address by DHCP but is instead set for only a static address. If that be the case, you will need to enter a static IP address in the TCP/IP settings. In that case, look for a number on the modem in a xxx.xxx.x format, enter the number in the TCP/IP static IP address but adding 10. If the address is static, you will also need to enter a default gateway, which your ISP should have provided to you, along with the static address
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!.
Jan 01, 2009 | Sony VAIO VGC-RB50 PC Desktop
Netopia router to strict
you need to open ports on your router so that it will give you proper connection to your ps3. you also need to set static ip address on your ps3.
here are the steps...
- go to a working computer that is wired to the router and open command prompt (for windows, click on start, then run, then type cmd or command, whichever will work, or click here if you are using mac)
- then you will be prompted with a black screen, on the blinking cursor type ipconfig/all
- take note of the subnet mask, default gateway, dns1 and dns2
- now go to your ps3 to set static ip adddress
* go to network settings and click network settings
* go to wireless or wired (whichever connection you are using for your ps3)
* then custom
* enter security settings
* now for your ip info click manual
* where it says ip address enter a static ip address (by default the ip address of your router is 192.168.1.254 so you can use any ip address that is on the same segment and was not being used by your other devices like 192.168.1.5 or 192.168.1.10
* subnet mask is normally 255.255.255.0
* put your default gateway number (the one that you have seen and listed from the command prompt) on the default router field
* enter the dns1 and dns2 also
* click next
* don't enable proxy server
* you can enable upnp if you can also enable it in your router
- now go bak to the computer and open a web browser, on the address bar of your web browser type the default gateway number (usually it's 192.168.1.254)
- you will be prompted with the netopia page, click expert modem on the left hand column, click yes, enter expert mode
- double click the word configure, go down and click on NAT, click static NAT, click the dropdown icon, see if your ip address (static ip address of your ps3) is there, if so click it, click on done, if this works, ignore the paragraph in brackets. (note: if it's asking for the default router ip address, you need to select/enter the default gateway number)
- click define custom service, click o port forwarding, select next , type anything in the service name, something that you will know its related to the ps3
- for global port range, if it's only one port that's being entered, enter the same port in the left and right hand boxes, in every case , enter the lower port in the box below saying base port even if there's only one port, and chage the TCP/UDP settings according to every port.
* here are the ports (note: repeat the same process for each one, after that window, select the static ip address you made in the drop-down list so it gets forwarded only for the ps3)
TCP port 80
TCP port 443
TCP port 5223
UDP port 3478-3479
UDP port 3658-3659
- when your done, click NAT on the left hand side, click the dropdown menu that has age of empires written on it and scroll to the bottom, click on the ports you made with the asterix beside them (*) and click enable , then enter the ps3 ip address in the bar , to enable them just for the ps3
- now click configure on the left and then click connection and tick the box that says upnp (note: you should have, when you click NAT on the left hand column, a static NAT address, enabled, it should be the same ip that you have used on your ps3, 7 ps3 ports, all enabled to the host device of your ps3's ip
- now , enter basic mode, click firewall, and set to low, this isn't dangerous as long as you have a desktop firewall such as windows or mcafee etc...
- save changes, and restart your router
hope this'll help you
ciao!
Aug 26, 2008 | Netopia 2247NWG-VGx Wireless Router...
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
117 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
