Question about Canon PC1061 Copier
Need to replace toner. Do I buy a whole new toner cartridge or just toner and if just toner, how do I put the liquid in? Thank you
    Sniper:
  • 66 Answers
It is always better to buy a whole new toner cartridge than to deal with the mess of trying to refill the old one. So therefore as a technician I would recommend you buy a whole new toner cartridge.
Posted on Aug 24, 2010
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
BROTHER-MFC7430 Toner life end
actually, you dont' really need to replace your drum, your drum actually is good for 5-6 years.
you just need to clean up the drum with duster and put that back into the machine.
when reset the drum, you just need to open the front cover and press Clear buttom then 1.
after that the whole thing will be reset and ready to go for it.
Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
http://www.tronix.ro/toner-samsung-scx4300-p-9783.html
May 27, 2010 | Samsung SCX-4300 Monochrome Laser...
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
I have a CLX-3160FN Printer and it says that my Magenta Toner level is low How can I fix that?
Have you tried putting a shim under it to make it higher?
Seriously...If the toner is low, you have to buy a new toner cartridge to replace the on that's low. No ink toner = no print.
Visit Staples, Best Buy, etc. to buy a new toner cartridge.
Nov 12, 2009 | Samsung CLX 3160fn All-In-One Printer
Need to replace toner cartridge, in brother 2850 laser fax
take the drum unit out which contains the toner cartridge, buy new brother toner cartridge and reinsert it in to the drum unit and then put it back into the machine and you will be good to go
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Canon LBP 3000 tells me it needs a new toner cartridge
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Sep 23, 2007 | Office Equipment & Supplies
Canon PC1061 Copier Logo
42 people viewed this question
old marine
old marine
