Question about Porter Cable Drills
How to remove a chuck on a porter cable 978 drill. Have take out lock screw and tried turning chuck counter clockwise with no luck.
  • 2,176 Answers
Go to the tip section and I put detailed instructions there, or under my profile it is there also. Let me know if still having problems
Posted on Aug 26, 2010
How to Remove Drill chuck from LxFD01 Makita drill
The screw in the bottom of the chuck is reverse threaded (left tight, right loose). It is also lock-tited so will be hard to remove. Make sure you have a screw driver well seated in the screw and turn it backwards (clockwise) to break it free. Once that is out, lock the short end of an allen wrench (at least 3/8" to 1/2") in the chuck. You'll have to lay the drill on a bench with the long end of the allen wrench hanging over the edge so you can hit it with a hammer hard enough to break the chuch free from the anvil. The chuck is threaded left loose, right tight so hit the wrench to turn the chuck counter clockwise. When you replace the new chuck use a small drop of lock-tite on the anvil threads and screw if it doesn't have some on it already.
Jan 22, 2013 | Makita LXFD01Z 18V LithIon Cordless 1/2-In...
How to remove chuck on porter-cable model 978 drill
Remove the left hand screw from the center of the chuck then lock a allen socket in the jaws and use an impact wrench to buzz it off right hand. If the jaws don't work then weld a nut to in and buzz it off with a regular socket.
Mar 23, 2012 | Drills
Hilti UH650, replacing the chuck
There are a couple of differant versions of the 650. Open up your chuck as wide as you can. Like you were putting a big bit in it. Look inside to see if you see a screw head. It might be slotted or torx. It will be left handed threads which means you will turn clockwise to remove. Once that screw is out you lock the front of the chuck in a vise and right behind the chuck will be a place to put a thin wrench. Turn the wrench in a counter clockwise motion away from the chuck.
Nov 17, 2011 | Hilti 284228 UH 650 Universal 1/2" Hammer...
How to take woodchuck off
If you mean how to take the chuck off, here you go. Open the chuck jaws all the way. There is a screw at the bottom of the chuck going into the shaft of the drill. If I remember correctly, it is a combination flat, or t30. This screw is reverse thread. Remove it by turning it clockwise. Once the retaining screw is out, get a 3/8 inch allen wrench. tighten the short end into the drill chuck. Lay the drill down on a work bench so that the long part of the allen wrench is hanging off the edge, facing you. The chuck comes off regular thread, so you are going to rotate the allen wrench counter clockwise. They are usually pretty tight. The best way is to put the drill in low range, and hit the allen wrench with a hammer so as to turn the drill chuck counter clockwise. Install the new chuck in reverse order.
Nov 21, 2010 | Dewalt 18 Volt Compact Drill Kit
Hello. My DC728 keyless chuck took a dive. I had
the chuck is screwed also to main shaft. counter clockwise to remove.
Nov 28, 2009 | Drills
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Nov 24, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck replacement
Hi Paul with the screw out you will have to lock the short end off a sturdy allen key in the jaws off the chuck then sellect first gear on the drill then with a hammer hit the long side off the allen key so that the chuck unscrews normal thread (anti clockwise) the shock off the hit will free the chuck.
Hope this helps.
Sean.
Apr 02, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
153 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Steve P
Steve P
Franco Pinto
Level 1 Expert
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
