Question about Intel Desktop Board D845BG (KD845BGPAK10) Motherboard
Ram Compatability Hi there, currently i have 2 sticks of KVR266X64C25/256 PC 2100 DDR in my motherboard and it works fine. However, when i went to put 2x KVR266X64C25/1G sticks in the computer just beeps at me and it on the monitor it comes up with "no signal"- i do not understand why this is occuring as according to the Kingston Website the RAM is compatible?, can someone please help me as i am a bit lost as to why the computer can't accpet the RAM. The motherboard is suppose to be able to handle up to 2GB of RAM so i don't know why this is occuring? could it have something to do with the CMOS battery or the Graphics Card?? any assistence would be greatly appreciated
Take out the cmos battery for five minutes after you disconnect everything off the motherboard and then put it all back together and it should be fine i just did the same with mine and it is working fine now seems to be a small conflict
Posted on Dec 14, 2008
Currently the KVR266X64C25 is PC2100 (133Mhz), 64 bits, the new ram is apparently the same??
Posted on May 05, 2008
    Genius:
  • 2,785 Answers
Just check the speed of the mother board for ram,if your ram speed is compatible with *********** board then you may have bad ram check it on another mother board
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
What speed,or memory that runs best in a syntax svm266a m.b.
The pc3200 would be best.
Do not mix different speeds together.
I'd go with the max of 2gig.
Mark
Mar 28, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Ram selection?
Your motherboard supports max of 2 GB PC 2100 RAM. Hope this helps.
Jan 10, 2009 | E-Machines (40-A06600-D201) for M2000S...
Memory problem
hi, are the sticks all the same type? make sure they are seated well, had same problem on my msi board, i seated them and moved them side to side carefuly. and it saw the sticks not detected before. also if they are not the same specs, there may be a compatability problem, most ram is backward compatable, but if not the same specs could be a problem. in my case the slots were worn from too many upgrades,and seating them properly worked. hope this helps you, happy new year!
Jan 01, 2009 | VIA MSI K8T Neo2-F K8T800 Pro Socket 939...
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
I want to upgrade Ram
yes there are different types of ram available but since u have a ddr 1 type of ram ddr2 wont match in ur maotherboard.and also do try to get the same type of ram available presently so u dont have problem with the clock speed.
May 12, 2008 | ASUS P5S800-VM Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
Intel Desktop Board D845BG (KD845BGPAK10) Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
