Question about Hotpoint HSS25GFP Side by Side Refrigerator
Need to know where the defrost timer is located tmdjy33re9
Where is the location of the freezer defrost timer
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
Oct 08, 2014 | Refrigerators
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
My Hotpoint CSX203A side by side refrigerator is warm on refrigerator side, but freezer side is fine.
Let's begin by looking for the defrost timer in photo here=> CSX20BABCWH Fresh Food Section Controls The part number is=> WR9X489 Sounds like you are not getting defrost and this is the most likely reason. Turn the defrost timer clockwise slowly until compressor and fans stop. Allow to remain like this up to 30 minutes and open freezer door and then listen for sizzling or crackle noise. This will indicate the fridge is in defrost. If the timer does not restart the compressor after this time simply turn again slowly clockwise until it starts. If this works the timer needs replaced. You have two other parts the defrost heater and defrost thermostat to check if the above does not work. Then click here=> .CSX20BABCWH Freezer Section Components See the part location 230 is your=> WR51X442 Glass Tube Heater Then finally the defrost thermostat is part location 240 and part number=> WR50X122 Defrost Thermostat
Try the timer first and let me know how that comes out and I will go through replacing the defrost Heater and defrost thermostat once I know how the fist test works. If helpful please rat if not then please tell me what I can answer from here, Thank You Sea Breeze
Nov 21, 2011 | Hotpoint Refrigerators
I am trying to respond to the defrost refrigerator problem but can't tell how to do so. The model is 106.70203990 Kenmore Elite Coldspot. I need to know how to troubleshoot the defrost timer and/or...
the defrost timer should be in the center hood, hanging from the refer section,
if you look up you should see the bottom of the timer
http://www.appliancepartspros.com/modelsearch_model.aspx?image=1&part_id=3110896&model_id=410075&pkw_=timer&x=14&y=16
it will look like this
you can turn it with a flat head
turn it till it till it clicks and the machine shuts off
it should turn the machine on in 20 mins or so
if it does its probaly good
the defrost heater is behind the back wall
its looks like a straight element , they best way to test this is to ohm it out,
no continuity, its no good
next while your behind the wall
http://www.appliancepartspros.com/modelsearch_model.aspx?image=1&part_id=3135377&model_id=410075&pkw_=thermostat
look for this part its your defrost tstat
make sure it looks just like the picture and not popped
sometimes this will actually pop open and be obviously bad
Oct 17, 2009 | Refrigerators
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Mar 14, 2009 | GE Refrigerators
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
215 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
