2001 TOYOTA HIGHLANDER DRIVERS SIDE AIR NOT COOL BUT IS BLOWING JUST LIKE PASSNEGER SIDE , PASSENGER SIDE IS COOL
  • 107 Answers
There is a damper that is not turning/closing completely so its mixing cold with hot air.
Posted on Aug 25, 2010
How to turn off check VSC in my Toyota Highlander 2004 model
for what its worth, my lights came on on my 2001 Highlander, I found this on the top back drivers side of air box.
Aug 28, 2015 | 2004 Toyota Highlander
Wet floorboard 2004 toyota highlander passenger side
Often the floor of the passenger side become wet if the drain pipe of the evaporator is:
- Bent or twisted.
- Clogged or,
- There is any obstruction in its routing.
The drain pipe is a rubber hose about 14 mm in diameter, located just under the evaporator (cooling coil) casing on the passenger side.
The most easiest way to clean the pipe is to take it out, wash it from inside with water or to blow a compressed air slowly through its distal end while leaving it in place under the body.
Note: Keep your eyes away while blowing the air.
Hope that it works.
Jul 10, 2014 | 2004 Toyota Highlander
I have a Toyota Highlander 2001 When i turn the heater on the red it will blow cold air?
have any coolant leak repaired lately?sometimes it is very hard to get the air trapped in the cooling system out.also there is something called a air blend door motor/valve under the dash.if you move the control from cold to hot you should hear something moving under the dash.
Oct 07, 2012 | 2001 Toyota Highlander 3.0
My 2002 toyota highlander has good air flow, however when the airconditioner is operating, one side (passenger) blows cold air but the drivers side blows ambient air.
You might wish to check the diverter box to make sure that it's blowing the right air in the right places. Also, check the dash ductwork-they like to split.
Jun 27, 2011 | 2002 Toyota Highlander
A/C is blowing much colder on passenger side
i use to have a toyota celica with same problem and all it was was that it needed to be charged.sounds like your problem have freon checked,
Jun 25, 2009 | 2002 Toyota Highlander
AC Driver side blows hot, passenger side blows cold
Try an A/C recharge. What is the temps of the discharge air from the vents?
Dec 27, 2008 | 2004 Toyota Highlander
2001 buick century driver side heat/cool problems
Sounds like a problem with the "Drivers side temp actuator motor".
Each side has a motor that controlls the temp. door inside the dash for the driver or passenger side. These motors are approx. $75, plus 1 hr. labor to install. See more info here...
http://www.greatautohelp.com/more-buick-questions.html
Oct 19, 2008 | 2001 Buick Century
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
