Question about Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ...
Have model KRP89S Table top just not getting cold enough. suction pressure box only 18 psi box & rail 46 psi rail only 33 psi. Thinking i may have txv problem.
1996 chevy 5.0 express van starts for about 10 sec. then dies, fuel psi starts at 60 then drops to 42 psi then dies, im thinking a pressure regulator if so where is it located.
Hi, try pulling the connector off your oil pressure switch and using a short jumper wire to connect the terminals inside. The switch is on top of the engine behind the distributor. If this works to keep the pressure up, replace the oil pressure switch. You may notice your oil pressure gauge spiking and/or the engine light may illuminate. This is normal with the jumper wire installed. Please let me know if this doesn't work or you have any questions.
Jun 22, 2011 | 1996 Chevrolet G10
2006 chevy 2500 express cargo van .What is a good oil pressure for this van. it has 150,000 miles runs great
60psi cold / 30-45psi warm is ideal. I've seen (with that mileage) 45 cold/ 20 warm and that's acceptable - anything less start thinking about a new oil pump.
Mar 24, 2011 | 2006 Chevrolet Express
Kairak modle#krp89s condenser fan and comprssor not comin on
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Jul 31, 2010 | Kairak KAI-KRP89S Prep Table 89""L (3)door...
Fuel pressure
30-45 psi with the vacuum hose attached to the regulator
40-50 psi not attached
Jun 01, 2010 | 1996 Ford Explorer
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
I have a 1997 Cadillac STS and the A/C doesn't blow cold very often.. The compressor will run for about 5 seconds bringing the low side pressure down from ~95 psi to ~40 psi then it shuts off for about a...
sounds more like the low pressure switch try that first u dont have to drain system for that,,,if it doesnt work they are two refridgerent temp sensors, u have to drain system first but u need to replace both so u know u have both coverd and dont have to go back in to system
Jun 28, 2009 | 1997 Cadillac Seville
Will a 1/3 hp compressor fire an 18 guage 5/8'-2" Finish nailer?
You compessor is ideal for a small spray gun however a pin nailer requires 80 to 100 psi and a small air storage thank to operate properly. The nailer may very well shoot a short nail into very soft wood at 30 psi, however there may not be enough pressure to push the piston back to top positon to load another nail and fire again. Good Luck
Jan 31, 2009 | Air Tools & Compressors
How can I start the soap syphon feature on the Karcher Model 210 - 1200 PSI unit ? Does the line need to be primed ?
If there is a check valve in the little line that you put into your soap tank, it doesn't need primed. I have very large 5000 psi units and have enough suction without one. If you can't get it going, you can always remove the hose end near the pressure washer end and fill it by immersing the tubing in the soap, but that shouldn't be necessary. Sometimes the little fitting with the check valve in the bottom get plugged up as well, so that might be your problem. Hope this helps you, Rick
Apr 03, 2008 | Karcher 2500 PSI Pressure Washer
Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ... Logo
Top Kairak Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Kairak Refrigerator Expert? Answer questions, earn points and help others
