Question about Dell Dimension E510 PC Desktop
Hi - I have a Dell E510 with a 160 gig RAID drive (or 2 160 gigs together). I swapped one out for a Western Digital 500Gig drive, but now I can't get the drive to show up on my computer. And the Intel RAID program rebuilds the drive as a RAID drive, even when I've tried to stop it. Should I simply swap the other 160Gig out, or will my system not boot up if I do this?
  • 119 Answers
You have to break the mirror of the raid assembly. There should be an option in the boot screen for you to control your assembly. You have to take away the raid settings in order for the HD's to stop replicating and act independantly.
Posted on Aug 25, 2010
750gb
3.5drives require 12vdc at no less than 2 amp recomended 12vdc 3amp it is always best to provide more amp for hard drive keep the voltage correct 12vdc
asme adaptors work out to 4 gig drives all my Western digital drive have same power adaptor no matter the Gig size .
May 05, 2014 | Maxtor Hard Drive
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Mar 02, 2009 | Computers & Internet
Dell d400 problems with Western Digital 32 gig hard drive
try connecting to a differnt port if it still does the same thing change the usb cable because what i understand is there is a loose connection somewhere ... or the best thing is contact dell at 18006249896 and ask them that u want to change the internal hdd and they will tell u what maximum the system can support and which is available with them ... its their system and if u buy parts from them they have to support u and make sure they both work
Feb 07, 2009 | Dell Latitude D400 Notebook
Hello i tried to insert files to my western digital elements 500 gig hard drive and after a few minutes an error message say cannot copy the file and the cause is either cyclic redundency error or I/O...
This is highly probable that the external Hard disk has failed. Not your fault , but due to manufacturing fault.
Pls return to where you have bought it, and request for warranty exchange.
Thank you for coming to FixYa and rating us.
Jan 06, 2009 | Computers & Internet
Western Digital My Book Pro - Replace Disks
Same problem. This from WD Answer ID 1664:
Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss.
So Hitachi drives will not work at all. After talking to tech support, it seems you have to have them send you a replacement disk in order for it to work.
I'm looking for a way around this since I want to upgrade my dual 500 G drives with dual 1 TB drives also. Maybe they throw something onto the boot sector that tells the MyBook controller what to do, who knows? The search goes on.
db
Oct 24, 2008 | Western Digital My Book Essential Edition...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Internal hd ata
If I am right on this one the 4600 can only take a 250gig hd But I was wondering if you could partion the HD to 236.7 gigs twice so the computer only recognizes the 236.7 gig hd you will see two drives in my computer once you do just format both partitions unless you have another hd and then you will see three drives just do the ones you installed or you may loose your operating system, I don't even know if that will work, but I think it is worth a try seems you already have the 500gig drive, can't hurt to try, I sure hope this help some what.,
Dec 22, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension E510 PC Desktop Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
