Question about Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3 Player / Dual Zone Capabilities
I have a pioneer dvh-5000 dvd head unit. I also have a pioneer ipod bus and 2 pioneer rear monitors and one kenwood front monitor. All video components play normally. Today I tried to run my rear speaker off of one of two amps which I have in my car, but like a dummy, I think I pushe subwoofer sound through a rear speaker so I think I caused a feedback or something because none of my car speakers play any sound anymore. My subwoofer still works and my amps and capacitors still function normally from what I can see. The only issue is that speakers are not getting any sound. I have tried to disconnect the speaker I was trying to run off the amp but still nothing. I checked all the standard car fuses and none were blown. I checked as many wiring fuses as I could see, but I have so many wires from all the a/v equipment it's hart to tell. Is there a fuse I am missing or is my head unit sound output just fried?
HOW CAN I TURN ON THE AUX IMPUT OF A Pioneer DVH-P7000 Stereo Receiver & DVD Player In Dash
Look carefully in the front panel for the source button- input. after connecting the RCA jacks input at the rear with a source, select this , do not put in the cd when you are trying out as it might go to the default setting of detecting the cd.
Hope you get this right.Good day
Jul 07, 2010 | Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3...
How do i switch my pioneer dvh 5850mp into auxiliary mode
here is the link to you receivers manuals:
http://www.pioneer.co.uk/uk/support/manuals/DVH-P5000MP/index.html
press source to select between sources:
dab turner-tv-dvd-sdvd-multicd-ext1-ext2-aux
this function is only avail on the remote. Source is upper right button above the round up/down/left/right toggle.
Cheers!
Nov 11, 2009 | Pioneer DVH-P5000MP Car DVD Player
Subject: Trouble shoot Samsung Synmaster 151 MP LCD monitor Hello, I have a NTSC compatible DVD player, (pioneer DVH-P7000) linked, pictured communication via S-video to the sumsung LCD, also NTSC. It is...
S-Video connectors have separate luminance (B&W) and chrominance signals.
Your symptoms are those of a bad connection on either pin 2 or 4, those responsible for chrominance signals. Check the connections and the cable. Try gently wiggling the connectors when the image is displaying. A flash of color imagery indicates that it is indeed a bad contact, hopefully in the cable (which can be replaced cheaply).
http://en.wikipedia.org/wiki/S-Video
Nov 02, 2009 | Samsung SyncMaster 151 MP (Silver) 15" LCD...
Dvd screens in headrests are not getting power
The problem seems to be that the video out from the kenwood head unit is either faulty or the leads from the head unit to the monitors are faulty. Have you checked to see that the head unit when playing a DVD is set on ZONE 2 so that it transfers the video signal to the headrest monitors?
Jul 12, 2009 | Kenwood DDX-6019 Car DVD Player
IPOD VIDEO PLAYS DISTORTED ON UNIT BUT WELL ON REAR MONITOR
souds like one of two things. u need to change it auxiallry or ur using a pioneer cable instead of clarion i tried the same short cut to asve money. but try selecting video in ipod control then switching to auxiallry to watch the video
Apr 07, 2009 | Clarion VRX785BT Car DVD Player
Connection to IPOD
There are many ways to do so. Each of which is progressively more expensive.
All of these plug into the Ip bus plug in the rear of the unit.
Most of these can be found on Ebay or Amazon
1: An IP bus to RCA plug then you need a RCA to 3.5mm plug wire. (note this is a lower quality) $10-$30
2: An ip bus to Ipod connect plug. (Better sound quality, charges Ipod, does not allow Ipod control from the Head unit, only from the Ipod) around $15-$30
3: An ip bus to Ipod Connectivity unit (same quality as #2 but allows for Ipod control from Head unit)
$100+
Feb 01, 2009 | Pioneer DEH-P3500 CD Player
Ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
May 24, 2008 | Car Audio & Video
MSI Star Cam 370i
Throw it away..that cam is a big ****...almost everyone has some probs with it..the most with colors..u can give it back to the store but when they will give u another one there's a big chance something will be wrong there too...
Apr 28, 2008 | MSI Starcam 370i Webcam
In car DVD playback question?
it will feed signal to alternate screen..but i dunno in motion..i cnt get a pic at all on mine still or motion...?????
Mar 18, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3 Player / Dual Zone Capabilities Logo
65 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
