Question about GPS
Wiring information for zig x70 - GPS
Zig cp3g control panel
  1. Click on the links below to open these manuals as a PDF file.
Please bear in mind that some of the small print may be very difficult to read as quality deteriorates through the copying process and in the case of the SP4/CP-3 & 400 it is only 1 page of a technical drawing. If you have any Zig manuals not listed below, please get in touch as I would like to get a copy to add to the database.
CF9 http://www.freewebs.com/12voltsdc/Zig CF9 Manual PDF.pdf
This also covers the CF9B, the "B" simply refers to the colour of the front panel.
There is also a slight printing error in this manual, if you look at the page(s) with the suggested wiring diagram and a diagram of 12S plug opposite, underneath the 12S plug it states " Connect terminal no 11 on the CF9 unit to terminal 6 ( red cable) on the 12S plug and connect the 12 volt positive wire from the refrigerator to terminal 12 on the CF9 unit. However if you look at the wiring diagram you will see that these connections are swapped over ( fridge to 11, 12S plug to 12). Zig have advised that these two terminals are in fact common so it does not matter which way round they are connected.
CF8 http://www.freewebs.com/12voltsdc/Zig CF8 Manual PDF.pdf
CF7 / ACU2 http://www.freewebs.com/12voltsdc/Zig CF7 and ACU2 Manual PDF.pdf
CF6/CF5 http://www.freewebs.com/12voltsdc/Zig CF5-CF6 Manual PDF.pdf
CF2000 http://www.freewebs.com/12voltsdc/cf2000.pdf
SP4/CP-3&400 http://www.freewebs.com/12voltsdc/Zig SP4-C3-400 Manual PDF.pdf
X70/X80 http://www.freewebs.com/12voltsdc/Zig X7 - X70 - X80 Manual PDF.pdf
X7 http://www.freewebs.com/12voltsdc/Zig X7.pdf
TX2000 http://www.freewebs.com/12voltsdc/Zig TX2000 Manual PDF.pdf
DCU3 http://www.freewebs.com/12voltsdc/DCU3.pdf
DCU15 http://www.freewebs.com/12voltsdc/DCU15.pdf
ZIG WATER GAUGE http://www.freewebs.com/12voltsdc/Zig Water Gauge.pdf
ZIG CPX7 BATTERY METER http://www.freewebs.com/12voltsdc/Zig CPX7.pdf
GENERAL ZIG CONTROL PANEL HANDBOOK http://www.freewebs.com/12voltsdc/Zig Control Panel Manual PDF.pdf
SYMPHONY SYSTEMS 2S4V http://www.freewebs.com/12voltsdc/2S4V Manual PDF.pdf
Please also note the following on commonly requested manuals:
E3 - Supplied by Zig to Explorer Group so any info / manual needs to be obtained from them.
MK103 - Supplied by Zig to Avondale so any info / manual needs to be obtained from them.
CP12V/CPX12 - as per E3 above
I also have a manuals for the ZIG X2 and Powermaster units but unfortunately they are not good enough copies to upload as the others above. If you require a copy of either , please email me for details of how to obtain one Email : 12voltsdc@blueyonder.co.uk
PLEASE NOTE THESE MANUALS ARE MADE AVAILABLE FOR PERSONAL USE ONLY - PLEASE DO NOT TRY TO MAKE PERSONAL GAIN FROM THEM. PLEASE REMEBER THAT THIS SITE AND ITS CONTENTS ARE COPYRIGHTED. CLUBS / FORUMS MAY USE THE MANUALS BUT ONLY AFTER THEY HAVE GAINED WRITTEN PERMISSION. STOP PRESS DEC 2009 - IT HAS BEEN BOUGHT TO MY ATTENTION THAT A NUMBER OF FORUMS / INDIVIDUALS ARE EITHER USING THE MANUALS WITHOUR PERMISSION OR ARE TRYING TO SELL COPIES - PLEASE CEASE AND DESIST NOW OTHERWISE YOU MAY FACE LEGAL ACTION AT THE START OF 2010. FORUM ADMINISTRATORS - PLEASE CHECK YOUR FORUMS ACCORDINGLY AS YOU MAY BE HELD JOINTLY LIABLE - IF YOU WANT TO USE THEM PLEASE CONTACT ME!.
Finally I would like to express my thanks to Zig Electronics for their kind assistance on the above plus the following kind people :
Ian McCormack for recently supplying a far better copy of the 2S4V than I previously had.
Wizard for a copy of the X2 manual.
Feb 28, 2018 | Cameras
Does anyone know what kind of motor, Servo or clutch, is in a HUSQVARNA huskylock 1002LCD? Also does it zig zag?
The information I found about your machine indicates it is a serger, not a sewing machine. A serger does not zig-zag.
Apr 18, 2017 | Husqvarna Sewing Machines
Its totally not normal when zig zagging
More information needed H. Refoh... what is totally not normal when zig-zagging?
Aug 30, 2015 | Sewing Machines
Where is the fuel filter on a 2000 x70 volvo?
v70?
it can only be 2 places,
on the feed line,
or in the tank, if you look at the line, and it not there?, most newer
cars its in the tank.
alldata.com shows
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Fuel filler cap
    • Fuel lines from the fuel filter
    • Fuel filter from the bracket
  4. V70 not X70 , ever seen an x70
May 09, 2014 | Volvo C70 Cars & Trucks
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
I have a different computer and i lost my software for my Pentax x70
You can use Picasa from Google its free
picasa.google.com/
Jul 07, 2012 | Pentax X70 Digital Camera
Pentax x70 operating manual in russian
Good Afternoon,
After extensive searching for you, I am only able to come up with manuals in English, French and Spanish.
For some reason they do not list the X70 model on the pentax.ru site, however you should be able to translate the pages using Google translator from the English version of the manual.
It will often say that the document is too large but if you break it down (I think pages 47-61 should be good enough... it's the quick start and basic settings section) you should have more luck.
I hope this helps a bit.
Lompanow
Feb 10, 2010 | Pentax Optio S5z Digital Camera
Hello my Samsung HT-x70 plays for about 20 minutes and then shuts off. Please help
First check in back that the fan is running. Second: Remove cover and check for bad capacitors in the back right corner. The ones in my system were blue. one had totally dissolved. I replaced the capacitor ad the system worked fine, Then found the fan was not running so replaced that too. It does take some soldering to repace the capacitor.
Jan 02, 2010 | Samsung HT-X70 Theater System
Samsung ht-x70 problem at loading dvd, it stay at a loading looping
I AM HAVING SAME PROBLEM WITH MY HT-X70 I HAD FOR ABOUT 3 YEARS NOW. I OPENED IT UP AND DUSTED THE LASER OFF BUT STILL NO LUCK. ONLY THIN I CAN THINK OF IS LASER IS BURNT OUT AND NEEDS TO BE REPLACED
Nov 02, 2009 | Samsung HT-X70 Theater System
Shampoo dispenser
Hello, How are you? First of all ,I would like to introduce myself who am I. I invented an automatic toothpaste dispenser not using any electric power like the ficturs. I am looking for a partner who sells the product as a dealer. when you are interested in the business, Pls. contact me. pls. view www.udson.co.kr for more information but it is written in Korean. I have two models ; um-150 ( 317(L)x55(H)x70(W) and um -550 ( smaller : 90(L)x80(H)x70(W) in mm. The difference in um-150 is to insert the brush inside the hole to dispense the toothpaste out. um-550 is to use one finger to push the button while another handed brush is positioned at the spot located bottm. Basic FOB price is USD 13.00 for um-150 (white only) with more then 1,000 pcs. USD 5.00 for um-550 ( two different model colors) with more than 5,000 pcs. This is the short information for you. If you need more informations, then I will answer all to you. contact No. +82-16-301-8354 Haward Ryu/udson/ceo
Jun 22, 2008 | Vacuums
GPS Logo
139 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
