Question about Frigidaire FRT21H8 Top Freezer Refrigerator
My new refrigerator is making a tapping noise occasionally, it sounds like ice is dropping but I do not have an ice maker. Otherwise it is working perfectly. Should I be concerned?
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
My ice maker makes a lot of noise at night I wake hearing it making ice droping sounds. I don't use a lot of ice can I turn the infrared receiving switch to off?
The noise is probably ice dropping into the pan and the normal ice maker and water valve sounds associated with making ice. Most Whirlpool models have a slide cover to "turn off" the ice maker - closing this cover fools the control into thinking the bin is full. Your owner's manual should provide greater detail on this option.
Sep 13, 2014 | Whirlpool Refrigerators
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Ice maker stopped working, makes tapping sound--like a woodpecker. How do I fix this?
Sounds like your ice maker has a bad heater or thermostat. While these are fixable, it is not recommended. Your best bet is to get new ice maker and replace the whole unit.
Dec 08, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker is making a creeking noise
I went in and knocked all the ice out and it started to work just fine.
May 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
May 02, 2008 | Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
113 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
