posted by Experts Arua on May 05, 2008
My Intel D845EPI Motherboard never displays any thing. I changed the power supply unit, put a new processor, changed the RAM chip, dusted the board but all was not positive, I real love that mother board and can't afford losing it. any thing technical i can do, please help
Solution #1
posted on May 05, 2008
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
http://cgi.ebay.com/PC-DIAGNOSTIC-CARD-4-Digit-PCI-ISA-POST-Code-Analyser-N_W0QQitemZ130196339829QQihZ003QQcategoryZ162QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Determine defects by difference sounds coding with build-in speaker.
It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
heres one
Comment by Ekse, posted on May 05, 2008
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Intel D845EPI Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
