Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Crystal wash and rinse only buttons flash and can't get any other button to work. Tried turning off circuit breaker and holding down set/cancel button but goes right back to the two buttons blinking, also in this mode dishwasher makes sounds but no water. Help! Thanks.
  • Frigidaire Master
  • 3,740 Answers
Without a model number this is my best attempt at trying to help you with out it. In the bottom of the tub look for either a float assy or a finger like thing sticking up from the bottom. If there is a float gently push it down first then try lifting it up about 1/4 inch movement you should hear a click. If your has the finger type sensor make sure the openings are clear of obstructions. What seems to be happening is the unit thinks it is full of water.... so you need to clear / clean either the float of the sensor. If you respond with a model number I can probably provide you with a location diagram of float / sensor.
Thanks for choosing FixYa.
Kelly
Posted on Aug 24, 2010
Why won't it run?
could be a defective door switch .
Nov 18, 2015 | Whirlpool Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and...
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Sep 14, 2010 | Dishwashers
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
