Question about Homelite Garden
Lost manual for Homelite Yardvark 25cc, what is my oil to gas mix set-up ?
  • 4 Answers
SOURCE: Homelite backpack blower M# ut08017l fuel mixter
32-1 will work fine for you
Posted on Feb 05, 2009
slohry
  • 87 Answers
SOURCE: WHAT IS THE SPARK GAP ON 25CC HOMELITE WEEDEATER
Gap is set to .030
Posted on Apr 11, 2009
slohry
  • 87 Answers
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Posted on Apr 28, 2009
  • 246 Answers
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
Need oil mix ratio for 25cc homelite gas trimmer
Hi anon the mix ratio is 50:1. That's five litres of unleaded and 100 ml of 2 stroke oil
Sep 10, 2014 | Craftsman 25cc Gas Line Trimmer
I have a Homelite UT20702 trimmer, a 25 cc engine. What is the gas/oil mixture supposed to be. Lost manual.
Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US). Do not use automotive oil or 2-cycle outboard oil
Here is link to owners manual too
http://www.homelite.com/system/manuals/stringtrimmers/ut20763_20778_20779_eng.pdf
Hope this helps
Please rate FIXYA
Jun 25, 2011 | Homelite Garden
Homelite 25cc 2cycle trimmer.built in March of 1999. what is the proper oil to gas ratio?
If you use a synthetic 2-stroke oil, you can easily get by running a 40:1 ratio mix...that is 3.2oz oil/gallon of gas. A richer oil mix won't hurt either (say 20:1 (2X the oil of 40:1). I recommend synthetic always be used alongwith Stabil fuel treatment because after about 30 days, gas loses its volatility and begins to breakdown without it...causing fuel problems.
Sep 11, 2010 | Homelite Garden
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Just plain gas or a mix in my Homelite 25cc zip start gas trimmer
you will have to mix oil and gas in a one gallon container
your ratio will be 40:1 that is 3.2oz of oil to one gallon of gas
you will need two cycle oil as some are pre bottled at this amount and some you have to measure as some dispensers have markings for you.
Do NOT USE MOTOR OIL OR OUTBOARD MOTOR OIL.
I would use 89 octane mid grade especially if fuel will be sitting.
Look for the 2 cycle oil that contains a fuel stabilizer in it if possible if not thats fine.
Dont want to throw you off but some will say you can use a 50:1 mix---2.6 oz to 1gallon
if you can find the SYNTHETIC type 2 cycle oil this would be your alternative and would be ok to use also.
Jun 15, 2009 | Homelite Garden
Rational for gas and oil
to lubricate the engine. there is no crankcase oil.
no oil= no lubrication=dead engine in no time at all
Sep 20, 2008 | Poulan 2-Stroke Engine Oil - 24 Pack
Garden Logo
385 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
