Question about Refrigerators
HI, I have a Magic Chef refrigerator (Maytag) Model#CSD2123AR*. I would like to know how to change the water filter. Please show me where to find it on my fridge. thanks Dom
fridgetech
  • 473 Answers
SOURCE: Majic Chef Freezer is collecting water at bottom and running out the front.
At the back bottom of the freezer there is a drain.  It is frozen.  Remove the rear bottom panel in the freezer.  Break up the ice (I use a small putty knife) and get all of it out including the ice on the bottom of the freezer floor.  Run HOT water over the drain until it drains freely to the pan underneath and your problem is solved.  Whirlpool makes a heat probe that connects to the defrost heater and sticks down into the drain hole that helps prevent this from happening again.  The part # is 819043 ($9-$13).  The heat probe is about 4-5 inches long so it depends on how close the defrost heater is to the drain hole.  If you look at this diagram the defrost heater is # 12.  I have seen people use a metal clothes hanger as a substitute but hanger must be tight around heater.  This keeps that drain hole warm.  Let me know if you have any other questions.9eg-hgejjf.gif
Posted on Oct 14, 2007
bobotfel
  • 236 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
Some technicians tried that, they just replace the compressor oil. But I did try that yet.
Posted on Jan 02, 2008
bobotfel
  • 236 Answers
SOURCE: Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Posted on Jan 21, 2008
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
peyton32034
  • 410 Answers
SOURCE: Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Posted on Jan 30, 2009
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
My refrigerator first stop making ice, then, a few days later, it stopped dispensing water. Help anybody? Elena
Don't know much about magic chef but you might want to check the water filter,if it has been in there for more than 4 or 5 months it might be clogged depending on your water.If this does not help repost your ?
Mar 01, 2011 | Magic Chef (CSD2610KRW) Top Freezer...
I have a Magic Chef refrigerator Model # GT17Y7A that I want to know what cubic feet it is? Can you help me?
I believe if you look under magic chef with the model number and serial number on google it will tell you, my sq ft is not written in the fridge.
Feb 23, 2011 | Magic Chef Refrigerators
Just bought magic chef ctf2124ar fridge. cannot
Not a bad refrigerator I work on them for a living they have put out decent products in the past. Magic chef was made by maytag in they past probably a wpl made product now. Its probably got a calrod defrost heater and an embraco compressor two good things to have. Stick with it.
Jan 22, 2010 | Magic Chef CTF2126AR Top Freezer...
I want to replace my old slide in gas range (Magic chef # 6498xts) with a new Maytag slide in (#MGS5752) and the installation drawings are showing different depths one shows 23 1/2 (magic chef) and the...
hi..gud day ur magic chef is smaller than maytag? do u think the space of ur old unit is enought to fit the new one? 5inc are different.u waste ur money.
Sep 10, 2009 | Cooktops
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
