Question about HP Officejet Pro L7680 All-In-One Printer
Every time I send a fax, I get a Fax Log. Want to disconnect the fax log.
  • lucindacrock Aug 24, 2010
    Under the FAX menu, there is not a DISABLE LOG or SET TO PRINT AFTER SO MANY FAXS. Please be more specific with your instructions.
  • 10,865 Answers
Hello. Go into the menu and disable the log or set it to print off a log after every, say, 20 faxes. J.
Posted on Aug 24, 2010
    Top Expert:
  • HP Master
  • 80,339 Answers
Silly u can't disconnect the fax log!@
Posted on Aug 25, 2010
Clearing the fax log on HP J6400 all-in-one fax machine
Once you print out the fax log it should clear the memory. Here are the instructions for printing the log.
To print the fax log from the device control panel
1. On the device control panel, press Setup.
2. Press the arrow key to move down to Print Report, and then press OK.
3. Press the arrow key to move down to Fax Log, and then press OK.
4. Press OK again to print the log
Dec 28, 2012 | HP Office Equipment & Supplies
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
Can't fax because fax log is full all the time
You need to clear the fax log. Press the control panel's button (right or left) until you see 'fax log' on the display, then press OK or Enter (depending on the printer). Press the control panel's button again until you see 'clear fax log' or 'delete fax log' on the display, then press OK or Enter. You should get a confirmation message on the panel display. You can turn the printer off and then after a few seconds turn it back on. The fax log memory should be empty now.
Nov 27, 2009 | Televison & Video
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
No answer when sending fax
The receiving fax machine never answered. Maybe their fax machine is set to MANUAL or is disconnected.
It's not your fax machine that's the problem.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP6450 says fax log is full and cannot recieve or send.
  1. Press the Setup button (c01361401.giftools ).
  2. Press the Right arrow button (c01185072.jpg> ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg >) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg> ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Jan 20, 2009 | HP DeskJet 6450 Printer
My HP Photosmart C6180 All-in One Series prints out a Fax Log after each Fax sent, How do I change the setting so that it prints a Fax Log only on request
Press the Fax Menu button twice to get to the Fax Menu to select or change Fax Options. I didn't see Fax Log in the manual, but I think they refer to it as a Fax Confirmation.
The only reference I saw in the manual was this:
"Note If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes."
Oct 20, 2008 | HP Office Equipment & Supplies
How can i refresh my send logs automatically ?
You can't, if a fax failed, and you leave it in the log, its listed there as a failure. If you're manually resubmitting the fax, while its in the outbox being re-transmitting or waiting, you can delete the old entry that failed in the send log. http://www.getfaxing.com/forums
Sep 08, 2008 | Symantec WinFax Pro for PC
Fax Log
Sure. You should be able to find the fax log in a folder in the folder for your Printer underC> Accessories or Programs> Ricoh. If you can find the fax, you can go to Edit in the toolbar>select all>copy and then paste it into a new fax. If you can automatically resend it from the log folder I am not sure. Look through the options there and see if you can.
Good Luck to you and Thank you for using Fix Ya!
Aug 22, 2008 | Ricoh Aficio SP-C210SF Printer
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
HP Officejet Pro L7680 All-In-One Printer Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
