Red dots on screen of
Red dots appear on screen when using hitachi projector model CP-S210
  • 4,234 Answers
Typically this is an indication of dirt in the optical path. Try blowing out the area using compressed air. Also, make sure that the lens is clean. Use a cloth and solution made specifically for cleaning lenses.
Dan
Posted on May 05, 2008
How do I change a bulb in a Hitachi CP-S210 Multimedia LCD projector?
There will be a panel that holds the lamp module in, usually on the base of the unit. Once removed the lamp is usually held in with two screws mounted on the body of the lam. Once replaced, ensure the lamp is correctly fitted and the panel then switch on and reset the lamp life in the settings menu.
Good luck, hope I was of help to you
Aug 04, 2011 | Hitachi CP-S210 Multimedia Projector
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Red screen
I had a similar problem with the same projector. Replacing the computer to projector solved it.
Oct 25, 2008 | Hitachi CP-S210 Multimedia Projector
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
External speakers
I would bypass the speakers from the projector and connect the audio output from the DVD to a sorround sound system or to computer speakers.
Jan 17, 2008 | Hitachi CP-S210W Multimedia Projector
Green backround on the image
My projector is not a Hitachi but I think the menus are similar. You might try finding "signal" under "setup" in your menu and check to see if it is on or off. You want it "on". I hope this helps.
Jan 06, 2008 | Hitachi CP-S210 Multimedia Projector
Projector image
First Check with any video Signal. Check the RGB Cable if that is okay.
Viren
Nov 11, 2007 | Hitachi CP-S210 Multimedia Projector
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
