Question about Sport & Outdoor - Others
Yamaha 25hp C25 outboard motor - Premium 703 Side Control. We can't lower the neutral throttle far enough down to engage the remote control lever to forward or reverse without the engine dying.
2 Suggested Answers
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
2009 Mercury bigfoot 60 outboard will not go into gear? What could be the problem? Runs fine otherwise.
Good Morning Anna,
Start At The Control Box,
Safety
1.Disconnect The Battery
2.Remove The Kill-Switch Lanyard
3.Remove Engine Cowl
Whilst Someone is turning the propeller operate the control lever into forward gear.
Check- Does The Control Cable Move a Lever At The Motor Side
Yes/No
Move The Control Lever Into Neutral Does The Lever Move at The Motor Side Yes /No
If Your Answer Is No Then The Problem Lies With The Control Box And Cables.
If Yes Then The Problem Lies Between The Lever You See Moving In The Engine And The Internal Gear Selectors Inside The Gear Housing.
If You Are able To Open The Gearbox And You Require Further Assistance I Can Guide You Further.
Hope This Helps
Regards
Gordon
Jul 09, 2017 | Mercury Boating
Is there any way to switch anything around in the control box in an outboard motor to make it pull instead of push the throttle lever on the side of the motor to make the motor accelerate?
Good Afternoon Ronnie Barnhouse,
Most Control Boxes Are Able To Be Switched,
Mercury Control Boxes Require A Lever To Be Purchased To Turn It Into Push Or Pull For Throttle. If You Would Like Specific Instructions Please Let Me Know The Type Of Control Box Or Post Photo.
Hope This Helps
Regards
Gordy
Jul 06, 2015 | Light Outboard Motor Boat Bass Fishing...
Johnson Outboard Motor Manual
its in the remote control box as you should have a kill lanyard button on the side so if you fall out it stops the engine ! split the box and easy replacement or check , make or brake reading on amulti meter set on ohms !
Jun 09, 2013 | Boating
2003 yamaha 25hp. outboard four stroke no spark at plug how do u check coil and control modgul
Hi Drxxxxa, for more information about your question please visit the website below. Good luck and have a nice day.
DOWNLOAD 25HP Outboard Repair Manuals
Jun 14, 2012 | Motorcycles
1971 MERCURY OUTBOARD ENGINE REVS WHEN PUT IN REVERSE
is that on the remote control lever ? if yes then adjust the throttle cable to push against the throttle stop on the engine end so when you select gears it only moves when you go to accelerate ! mite need to adjust the carb pickup to align with mark on main lever that moves the timing rod to the trigger under the flywheel !
Sep 30, 2011 | Light Outboard Motor Boat Bass Fishing...
When the boat is in nuetral it can rev up when it is in gear out of the water it runs good when it is in gear motor lowered in the water it wont go above 1000 rpms yet when i take it out of the water and...
The last comment you made about the hose cuffs and running good- Was that in gear or neutral? If you are using the boats throttle lever there is a cam lever for the choke which limits the throttle. It may be out of sync in the control box. If you have operating cables disconnect them at the engine and see what range of motion you have in the motor itself. Then hook up the controls and see if the cables prevent the motor from opening the carbs.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Jul 07, 2009 | Boating
1990 mercury 150 outboard motor
sound like the throttle control (lever) is at fault not engaging the throttle in FWD position, but ok when in neutral, check the release button insure it pops out to lock the throttle...hope this helps...GL
Jul 06, 2009 | Boating
It will not go into reverse but will go into forward. what should i do first? 1986 mercury outboard
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
May 17, 2009 | Boating
Sport & Outdoor - Others Logo
132 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
