Question about Patton U2-1487 Floor / Box Fan
Bad switch, how much is a replacement - Patton U2-1487 Floor / Box Fan
    Sergeant:
    Champion:
  • 342 Answers
These switches range from 10-20 dollars and are easy to find online search three speed rotary switch in google
Posted on Jan 01, 2011
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
How to reset the safety on power windows
You will either have to replace the drivers master window switch or you have bad window motors. If you can still control the windows on the driver switch then the safety switch is bad and you need to replace the whole master switch. If the windows still can't be controlled by the front, then the motors may be bad.
Jul 21, 2014 | 2004 Nissan Titan
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
Switch bad need to bypass switch
Monica, I highly recommend you replace the switch. By passing the safety of a switch on any appliance or tool endangers both yourself and those around you. Just to by pass the switch, you would need to disassemble the appliance. If you are going to do this then get a replacement part and replace it. :) Safety comes first , especially where mechanical and electrical devices are used.
Nov 08, 2013 | Shop Vac Vacuums
I own a 2003 Yukon XL. When I use the right hand turn signal, the hazards come on instead. Solutions, answers?
When you touch the turn signal lever do you hear clicking noise befor u lift up or down if so then could be bad turn switch or just bad relay replace relay first if still doing it replace the switch get Haynes book to help with switch removal and install if relay don't fix it cause u will have to remove steering wheel etc to fix it if switch is bad
Feb 21, 2013 | 2003 GMC Yukon XL
93 century cooling fan dose not run
First check fan fuse and relayand switch.You can change relay with another with the same part number to see if that relay is bad.Then check power to and from fan switch if switch has power coming in and not going out then your switch is bad. Replace switch.If fuse and relay are good check for power at the fan and if you have power at the fan then that means that your fan motor is bad,Replace fan motor.HOPE THIS HELPS!!!
May 04, 2011 | Buick Century Cars & Trucks
Starter and cealunord have been replaced but the truck will only crank if you cross out the cealunord. replaced cealunord again and it is still the same
When you jump solenoid you are bypassing ignition switch. You either have bad wire or bad ignition switch. Trace small wire off solenoid to electrical ignition switch at bottom of steering column. With ohm meter see if it reads 0 if so wire is good & most likely switch is bad.
Dec 14, 2010 | Ford F-250 Cars & Trucks
Climate control blower switch operates on one speed only
its the "blower resistor". thats what you need to replace.
Sep 23, 2009 | 2003 Mercury Sable
Replaced all bulbs in the tail light assemble, still no turn signal or brake lights coming on. Repalced the fuse, still nothing.
try replacing the turn signal switch flasher and check to se if brake switch is bad, if it's bad replace it if it still does not work replace turn signal switch.
Jul 18, 2009 | 1999 Chevrolet K1500
1989 toyota camry blower just stopped
find your fuse layout or owners manual and check the fuse and replace it even if it looks ok,thencheck to see if the switch itself is bad,if so replace it by removing the screws,(4-6) and dash cover checking the connection and switch,replace which ever one is bad and turn on the car,turn one the switch if nothing happens the switch is bad replace and enjoy!
May 18, 2008 | 1989 Toyota Camry
Patton U2-1487 Floor / Box Fan Logo
269 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Patton Dryer Expert? Answer questions, earn points and help others
