Question about Canon PowerShot A450 Digital Camera
Stuck on Black screen
After turning on the camera, the screen shows black with instructions to "Change The Batteries."
I have changed batteries a number of times - including brand new ones - same non-response. Can't get beyond the black screen. Used only for still shots.
Hey buddy.....Know this first.....
Canon needs higher power batteries. You cant use Nippon of any other battereis that you use for clocks & other stuffs like torch..Buy a higher power battery....
TIP : Buy high power RECHARGEABLE BATTERIES. It cost you 200. Its must to buy a Battery charger. This combination will give you life long Battery.
No Hassles of Changing battery for every photograph...
Posted on May 06, 2008
I put new batteries in and I can take 1 picture then the screen goes black and it says change the batteries. What's the problem
I would try cleaning the battery terminals with a swap and a bit of rubbing alcohol.
See if that helps. Just a suggestion. Maybe the battery terminals are dirty.
Oct 30, 2011 | Canon PowerShot SX100 IS Digital Camera
When I turn the camera on and look through the viewfinder, it's black. Also, if I flip open the little screen, it is black. It does show the little icons, but it's as if the lens cover is still on (which...
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
Jan 13, 2011 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
Hi i have a CANON A1000 IS and I just got it a week ago and the batteries lasted me 2 days. I tried charging my camera but when i went to turn my camera back on it said low batteries then immedietly after...
Are you installing Nmh (Nickle- Metal Hydride) rechargable batteries?
If not then your camera probably will not recharege them.
Also trying to recharge non rechargable batteries can cause damage to the battery, and possibly your camera.
Hope this is helpful.
Tom
Jan 05, 2009 | Canon PowerShot S100 Digital Camera
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Samsung A506
Sounds like its broken. the black ink stuff could mean the screen is cracked and it has bled internally. I had the same problem (screen bleeding). the not-turning-on part could be because ur not using full batteries, the batteries are not in the right way, or the screen crack is shorting something inside and not allowing the device to come on. get it replaced. when you turn it on press the menu/ok button is there any noise, tune. this happens to me to show its entered the menu section. if you are getting this sound, then its turning on but the screen is cracked. if not then you have a dead camera or change the battery positions or use new batteries.
Sep 20, 2008 | Samsung Digimax A503 Digital Camera
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 27, 2008 | Canon PowerShot A540 Digital Camera
This sounds like it might be a defective CCD imager. Take a picture and see if it is also black. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
The little 3 volt button battery is the clock battery for the camera. It keeps track of date and time.
Feb 04, 2008 | Canon PowerShot A300 Digital Camera
Canon PowerShot A450 Digital Camera Logo
139 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
