Question about Refrigerators
Can I hurd the refrigerator if I defrost the freezer by using a garden hose and spraying it with hot water?
  • hadams362 Aug 24, 2010
    It is too late, I've already did it and now the refrigerator is not coming back on!
  • 4,793 Answers
DO NOT BE SO IMPATIENT. use car deicer instead,then rinse out with clorine bleach and leave to dry thoroughly.....PLEASE do not use any scrapers or hot water......
Posted on Aug 24, 2010
  • geoff hunter Aug 24, 2010
    let it dry naturally.it may work again it may not..........
Water dripping in refrigerator.
The drain hole in the freezer section is frosted up . Easily fixable .
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jun 25, 2010 | KitchenAid KTRS19KMSS Top Freezer...
Water buildup inside refrigerator. Source back or fridge from freezer section. It appears it is defrosting all the time.
May 25, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The freezer floor of my refrigerator freezer (top freezer) has ice on it. There is some water in the refrigerator section.
First what you have to do is unplug it and leave door open over night, tto let the ice melt down. Then when you go back the next day, you need tto check if the defrost timer is working, if it is you need to check the heater and if thats ok you need to check the thermostat, One of these 3 things are gone.
Jan 20, 2010 | Kenmore 64192 / 64194 Top Freezer...
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Jun 02, 2009 | Refrigerators
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Kenmore 62832 / 62834 / 62839 Bottom...
Lots of water in bottom of refrigerator
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Estate TT14DKXKQ Top Freezer Refrigerator
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water in freezer
The defrost drain is frozen. It is located at the back bottom of the freezer. Use a hair dryer to thaw it out and when thawed run hot water through it to check. Afterward, spray some "Pam Cooking Spray" into the drain so the water won't stick. This can be caused by the controls being set too cold or something in the drain line.
Jan 19, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
