We have an NEC NW452 4.5kg fuzzy logic air bubble washer, when we turn it on to do a load the program button only works sometimes so we are sometimes forced to do a 76 minute soak cycle. Any help or advice would be appreciated. Thanks Nathan & Carla
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
JULIANFIX
  • 975 Answers
SOURCE: NEC NW452 4.5kg washing machine - spin cycle not working
theres 2 things to look for , 1 the LID SWITCH that tells the main module that is OK to SPIN, it could be loose or defective (need a multimeter to check the voltage on switch) 2 the DRAIN PUMP MOTOR , usually it gets stuck with lint and debris, need to open washer ,locate at the bottom on one side where the DRAIN hose is connected, is a small motor , take it out and check inside for clogged stuff , also check drain hose , hope this helps , AJ
Posted on May 16, 2009
Dissolu
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
  • 3 Answers
SOURCE: My NEC Fuzzy Logic 6.5kg
I had the same problem, When calling a repair shop I told the mechanic it was coming up LE on the display. He told me it was a lid error. Which made perfectly clear sence. I checked the lip of the lid and there it was, a piece broken off where it hits the saftey switch. (my switch was on the left). So check the strike plate on your lid. You may have to screw a piece of alaminium angle to replace it. Or replace the lid.
Posted on Nov 24, 2009
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
We have Fuzzy logic and the smell s unbearable. We
The smell is residual soap and grease left behind in the machine because the wash temperature used is not high enough to kill it off also the detergent has been sanitized to a point where it also dislodges the grease but does not fully emulsify it
Go and buy one or two large boxes of common washing soda mix them in a bucket of very hot water.
Pour this mix into the tub before you start the machine , fill the machine using a high level very hot program and do a wash without any clothes in the machine.
You may have to do this twice.
Change your soap powder to one of the older type brands which contains bleach and soda (Daz, Omo ??).
When the machine has finished its work leave the lid open for an hour or so to allow air circulation to dry out the drum inside
Nov 10, 2009 | LG WFT1071TP Top Load Washer
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
