Question about Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator
Refrigerator makes a loud knocking sound at random. May go for days without making the noise, then will make noise randomly throughout the day for several days in a row. Freezing compartment, frig, water and ice dispenser are working.
  • 6,784 Answers
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Posted on Aug 24, 2010
LOUD VIBRATION NOISE COMNG FROM FRIDGE WHEN WATER BUTTON DEPRESSED. ALSO NOISE COMES RANDOMLY THROUGHOUT DAY. WATER LINE IS NOT FLOWING WATER EITERH..
It's the solenoid on the water valve. Power is getting to it but it's not opening so it just sounds like a buzzer. It's usually located in the back on the bottom where the water source enters the appliance.
Sep 13, 2015 | Refrigerators
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Random knocking noise
There is a broken spring on the internal mount for the compressor. The only fix for this is a new compressor. If you can put up with the noise leave it alone. Expensive to replace compressor
Jan 05, 2009 | Whirlpool GS6NBEXR Side by Side...
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Jul 28, 2007 | Dell 5650 Computer Speakers
Speaker issues
This is a duplicate posting, click on the following link to read the active post: http://www.fixya.com/support/t161863-loud_strange_noises
Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator Logo
569 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
