Question about Google Chrome
Crashes when print command is attempted - Google Chrome
    President:
  • 2,291 Answers
There could be registry problem, update ur chrome, download reginout to solve it
Posted on Aug 31, 2010
49-2F9D Service error
49:xx xy fault code is Firmware crash , look at the 49 error as bieng like a blue screen crash on windows, there are many things that could cause this to show- what to do-
disconnect both the mains cable and any other network/usb cables that are connected to the printer.
allow 20 seconds for the ram to clear. then re- power the printer still with no network connections, allow to come to fready - at this point you should try to get an info page from the printer ( use the menu(tick) button then scroll down once then press menu(tick) twice. this should now print out a information page and also at the same time you will have proven there is nothing wrong with the printer.#
BEFORE re-connecting the network to the printer - CLEAR ALL PRINT Queue's from the workstations (pc) as the likely fault is a corrupt print file, if you dont clear the print queue then the printer will attempt to print the failed file again and again and again and again and ag-sod it you got the idea
Feb 18, 2014 | HP LaserJet 2420 Printer
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Epson 4880 incorrect paper source setting
you have to chose sheet paper before sendding the print command.
Apr 02, 2013 | Epson Stylus Pro 9800 InkJet Printer
I am getting the following error message with the Seagate GoFlex 2TB wxternal hard drive after it fell a short distance10 inches. my computer recognizes it and i can see all the files but cannot access...
Open up a command prompt with the command Windows key+R or go to Start>Run...> and type the command "cmd" and press Enter. At the command prompt window, type the following command:
"chkdsk X: /f" Where "X" is the drive letter of your external device. This command will scan your drive for any virtual errors that may have occurred, and attempt to fix them. If this does not solve your issue, it is best to call Seagate for a replacement of some kind
May 09, 2011 | Computers & Internet
The print spooler service is not running iam using MP830 printer
There are a few different causes for this. All of them leading to the "spooler" service to stop running.
The most common remedy is to just reboot the computer. If this fails, there may be a corrupted document in the spool queue that is crashing the service repeatedly here are the steps to clear it out:
For Windows XP (your computer says "start" in the bottom left)
1. Go to the "Start" menu and click "run"
2. in the window that comes up enter "net start spooler"
3. Try printing again.
4. If the problem continues then:
5. Click "start" and "Run" again.
6. enter "C:\Windows\System32\spool\PRINTERS" and click ok and delete any items in there.
7. Close that window.
8. Restart the computer.
You should now be able to print.
For Windows Vista or Windows 7:
1. Click the blue "Start" orb
2. In the search box enter "command"
3. The computer will return with several items
4. Right click on the black item that says "command prompt"
5. click "run as administrator"
6. in the black window type "net start spooler" and press enter
7. try printing again, if it fails continue to step 8
8. open the blue start orb
9. in the search box enter "C:\Windows\System32\spool\PRINTERS"
9.5. If you get a permissions message click continue
10. delete all items from there.
11. back in the black command prompt box, type "net start spooler" again
12. You should be able to print.
If you still cannot print, you may have one or more corrupted print drivers. In this case you will need to delete and re-install your printers from the computer using instructions from the manufacturer.
May 02, 2011 | Canon MP830 All-In-One Printer
It will not print what I want it to because it says there is a file ahead of mine. The file ahead of mine has been attempting to delete since 8-1-10. What should I do?
Stop and restart your print spooler. For Windows, open the command prompt (Start > All Programs > Accessories > Command Prompt (right click and choose Run as Administrator for Vista and Win7)). Type "net stop spooler" without the quotes followed by hitting enter. Press Y and enter if you get prompted about another service stopping (Fax). At the next prompt, type "net start spooler" again without the quotes followed by enter. After the second command executes, restart the computer.
Check the queue for any documents and then retry your print job.
I hope this helps.
(if you are using a networked printer, you may need to do this on the computer that is acting as the print server, not just the local machine.)
Aug 17, 2010 | Lexmark Office Equipment & Supplies
I connected a Dell 3010 CN to my computer running Windows Vista and Microsoft Office 2007 Professional. Many issues getting it conncect. It will print OK using Adobe PDF, etc. However, every attempt to...
its no support office 2007 font please request service vandor thay solve properly or install office 2003 then solve problem,may be its problem office 2007 not printer
Nov 21, 2009 | Dell 3010cn Laser Printer
HP Deskjet 5740 causes application to crash when trying to print
need to install printer driver again.
download free http://www.nodevice.com/driver/Deskjet_5740/get39181.htmlm here then install.
Jan 10, 2009 | HP Deskjet 5740 InkJet Printer
Google Chrome Logo
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
