Question about Apple iPhone Smartphone
My iphone was working when I plugged it in to charge it but then this morning was blank and now will not turn on. How do I retrive all my data?
  • 320 Answers
Hi try to press home button with power together for 10 sec it should go to restore mode and after few minutes (you will see apple logo on the screen) should work.
Posted on Aug 24, 2010
My iPhone 5c isn't working it turns on and then fades away
Have you tried to charge the phone?
Plug it into the charger and wait for it to charge, confirm that it is charging. After it has ample charge, disconnect it and try to turn it on again. If this does not work, try leaving it plugged into the charger, then power on the device.
How old is the device?
Typically, if the iPhone 5 does this, it is the power source.
May need a battery replacement, but if it is also not charging, it could be the data port.
Mar 15, 2015 | Apple iPhone 5
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
Sep 22, 2014 | Apple iPhone 5c
My iphone 3gs will not charge or conect to itunes
REplace your data cable.If not working that also.... check you port of iphone.And try different USB port.
Thanks.
Feb 18, 2013 | Apple iPhone 3G
I walk up this morning and i found my iphone not working , not even showing any sign that a battery is down if i charge like its dead, yet before i slept at night, i left it charging but its battery w
Have you try to do a hard reset by simultaneously press on both Home and Turn off button. It can be a system crash. other way, you can try to plug your iphone to a PC and use "tiny umbrella" or others to exit recovery mode.
Jun 18, 2012 | Apple iPhone Smartphone
Tried to erase all data, iphone froze at the apple
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
May 11, 2010 | Apple iPhone Smartphone
Morning how do I retrive data from a failed hard drive
Retrieving data from a failed harddrive can be very difficult and often expensive. If the failure is a result of an overheating motor, one way that I've been able to do it is by putting the harddrive in a sealed plastic bag and putting it in the freezer for 1 hour. Immediately place it in your computer and fire it up. If it works, recover your datat quickly has it will fail again as soon as the motor overheats.
That being said, if this data is absolutely critical, do NOTHING to try and recover it and send it in for professional data retrieval. I say this as any recovery efforts on your own may possibly damage your harddrive further.
I have used Seagate's data recovery service (all makes and models accepted), but be ready to spend quite a bit ($800+). That isn't much if the data is critical.
https://services.seagate.com/
May 01, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Retrieve iphone backup
You will be able to retrive the backup from Itunes or the location of the back up by default is
->If your using a PC then it is "c:\users\YOUR USERNAME\AppData\Roaming\MobileSync\Backup"
->If your using a MAC then it is "~/Library/Application Support/Mobile Sync/Backup"
NOTE: "~" is the user folder.
Feb 26, 2010 | Apple iPhone 3G
My iPhone 3G suddenly stopped working. The screen
In certain situations, an iPhone will automatically go into recovery mode after an update or restore issue. If your device is already in recovery mode, you can attempt to restore using iTunes.
Please follow steps on this link http://support.apple.com/kb/HT1414
Note: Restoring your device will delete all the data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Nov 20, 2009 | Apple iPhone 3G
I HAVE APROBLEM iPhone 3g i deleted all the programs.what should i do to retrive.
As a matter of fact, every time you sync data between iPhone and iTunes, all previous data will be automatically backed up by iTunes and stored as a .sqlitedb file, which will be updated along with the later sync continuously. But those backup files can't be viewed or taken out unless you use some software using special algorithms to extract. Learn how to recover your iPhone data with step by step guides here:
http://www.anysoftwaretools.com/iphone-data-recovery.html
Nov 07, 2009 | Apple iPhone 3G
After getting off of my iphone the screen blanked out when someone calls it will ring but the screen stays blank can apple fix this?
You can fix this. Just restart your iPhone by holding down the power button and the home key. Then while the iPhone is turned off, plug it into iTunes with your data cable. That should fix the problem.
Jun 16, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
