Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
How to bypass seat safety switch. There is a Red Grey, and 2 Black wires that plug into the bottom of seat
4 Suggested Answers
SOURCE: Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Posted on Mar 31, 2010
al_kupchella
  • 843 Answers
SOURCE: How do I bypass my seat safety switch on my
It's not a good idea. But if you must, it's just a switch. If it has two wires, cut them from the switch and connect them together with a wire nut. If it has only one wire, then cut it from the switch, put a spade terminal on it, and connect it to the frame of the tractor.
Posted on Jun 29, 2010
  • 5 Answers
If it is a temp. fix unplug the harness and use a jumper wire across the plugs. This will tell you if the switch is bad preventing the tractor from functioning properly.
Posted on Sep 12, 2010
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why does engine stop, when I take foot off brake pedal?
1 safety switch under seat. 1 on deck engage lever. 1 on brake. It sounds like the brake switch is working. its most likely your seat switch that is bad or out of adjustment. you can try bypassing switch by unplugging it from wires and run a piece of wire between the 2 contacts on the plug with the wires. If that works you need a new seat switch.
Jul 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replaced battery and will not make a sound
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
L130 mower shuts down when getting off seat with parking break set and PTO disengaged. I know it's safety lock circuit problem, but I don't know how it's wired
you can bypass the seat switch and see if the switch itself is bad, I do not know on a JD but on a Cub Cadet the RMC controls the safety switches, which is a small black box with a connect plugged into it. Hope this helped Tim
May 21, 2011 | John Deere 22HP VTwin 48" Riding Mower
Okay, I have a Ariens, Sport Zoom, Zero Turn, 12 HP mower. The battery was dead. It has a built in kill switch for safety. If there is no weight on the seat the engine shuts down.The battery is located...
Hi Tina, yes you can do as you asked and this will bypass the seat switch. No there is no need to disconnect the battery as the wires are not live unless the mower is running. Regards Phil.
Apr 21, 2011 | Briggs & Stratton Garden
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
How to hardwire rowenta powerglide to bypass safety switch
lancell - you're an idiot...of course he understands - that is why he is asking!
Sep 24, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Looking for towbar wiring diagram for MB W124.
You need to use a bypass relay on this car. the car colours are - L/Ind = Black/White, R/Ind = Black/Green, Fog = Grey/Green, Brake = Black/Red, Left tail = Grey/Black, Right tail = Grey/Red
Aug 31, 2009 | 1990 Mercedes-Benz E-Class
1998 craftsman mower w/19.5 hp Briggs and Stratton will not fire.
Hello B-N-L:
>>I Suggest you Check the Ign Module First and then the Safety Switches if the Ign Module (Coil) is Good. Remember that the Ign Module May Check Good, but if the Safety Switches Check Good, then Most likely the Coil is in the Early Stages of Breaking Down and will Cause this Problem.
>>You can Check the Ign Module (Coil) by Using the Following Instruction File.
The Following is an Instruction File I Made for Checking and Repairing this Problem.
>>Run the Engine Until it Quits, then Remove the Spark Plug. Wrap a Wire Around the Threads and Attach the Other End of the Wire to the Engine Block Turn the Engine and See if the Plug Fires.
>>If No, then Disconnect the Shut Off Wire at the Control Bracket First, Check for Fire at the Plug. If Still No Fire at the Plug; Then Disconnect the Shut Off Wire at the Coil (usually requires removal of the blower housing) and Check for Fire at the Plug.
>>If No Fire at the Plug , then the Coil/Ign Module is Bad. The Coil/Ign Module to Flywheel Gap is .020in.
>>On Some Model JD Engines, there is a Igniter that Goes Bad and Not the Coil. The Igniter is the Same as an Ignition Module. If the Plug Fires at Anytime During these 2 Checks, then a Safety Switch or Wire May be the Problem. Yes the Engine will Turn Even with a Bad Seat Safety Safety Switch. Usually if the Engine will Not Turn with the Ign Switch; the Blade Safety or Neutral/Clutch Safety Switch is Usually the Cause of this.
>>The Starter Turns and the Engine Doesn't Fire is an Indication of a Bad Coil/Ign Module or a Faulty Blade Safety Switch.
>>The Blade and Clutch Safety Switches Prevent the Starter from Engaging so the Blades or the Mower Does Not Move when the Starter Turns the Engine.
>>The Seat Safety is Designed to Stop the Engine if the Blades are Engaged or the Clutch Safety is Not Engaged when you Leave the Seat.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire.
>>Check the Clutch/Brake and the Blade/PTO Safety Switches First.
>>Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Volt/OHM/Continuity Meter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>If the Safety Switches Check Good, then Check the Ign Module (Coil).
>>Thanks.
Respectfully
John
Apr 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
408 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
