Question about RCA Televison & Video
THE PICTURE IS NOT CLEAR A SHADOW BEHIND OBJECT, THE SCREEN IS OVAL
    Scholar:
  • 85 Answers
You most likely have a large magnetic source near the screen like a surround sound sub woofer or other speakers. also go into the tv's settings and have it auto adjust the convergence. should help
Posted on Aug 24, 2010
My Fujifilm FinePix A800 is not displaying any image
This camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Apr 18, 2012 | Fuji FinePix A800 Digital Camera
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
The Tv just got a green ring around the edge of the picture
If this is a TV with a CRT (glass tube screen) then this pattern will be caused by a residual magnetic field in the shadow mask (the metal bit at the front behind the glass). Normally when a TV is turned on from cold a set of wire coils demagnetize (or degauss) the set and clear these patterns. If this circuit is not working you will have to take it to a repairman and get him to do it manually (or the shadow mask in twisted). In future handle the set with care and keep it away from strong magnetic fields (vacuum cleaner motors, etc).
Dec 21, 2008 | Televison & Video
I have a 42 flat screen projector. The picture i see doulbe the normal color of the letter. then behind the letter they show up in different color. Then when there people on the screen or object there...
The colors have to be aligned most systems have a calibration screen with in the setup menu
Follow the instructions .... this is a common issue
LB
Sep 21, 2008 | Televison & Video
Calypso Dryer thermistor replace
if e1 is thermistor code remove bottom panel look behind lint screen housing should be a black oval object with 2 wires just behind housing and to the right of the white thermal fuse
Sep 03, 2008 | Dryers
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Blue Half-oval on screen
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Hitachi 51F510 51" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
