Does this unit require batteries? I plugged this game in and set the TV to the right source, turned the switch on the game to on, and don't see anything. It has been sitting around for a few years. I figured if it requires batteries, they may be dead, but i'm not sure if it takes them and where the battery hatch is. THanks
Make sure you've unplugged all external connections to unit. Try unplugging TV from power source for no less than 10 minutes. Plug in again, and see if it comes on by depressing the unit's ON/OFF switch (NOT via remote). If not, then try something in receptacle that you're plugging into. If no power, then check your circuit breaker. If still no power, then may require service.
Installation steps: These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR. Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono." Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo. Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary." Make sure the game is placed properly in the system. Plug the controller(s) into the front of the Control Deck using the left most port for player one. Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet. Turn the power on. Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game. Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
If your remote serves multiple units, make sure it's in the right mode for your TV. (not dvr, dvd player, tuner, other source...). If the TV will not turn on manually (with the power switch on the TV), then make sure it's plugged in and there is power at the plug (try a different power source). If your remote has been out of battery power, sometimes it needs to be reset / reloaded with the correct code for your TV. Check your remote and / or your TV manual for the procedure.
Make sure the cord is plugged in tightly at the TV and at the wall.
Try turning it on from the power switch on the TV (not the remote - batteries in remote may be missing or bad (if they came with the set).
Some TV screens appear dark / off if there is no signal so make sure the cable or antenna is plugged in (or dvd if that is all you will use).
Try clicking through the different input sources (Should be a SOURCE or INPUT button on side of set. Use remote with good batteries if you don' t have a button on the set.
If those options fail, put it back in the box and return it - the set it bad. Sorry.
Check your A/V cable connections. They are the Yellow (Video), White (Left audio), and Red (Right audio)wires coming from the back of your PS2 to the connectors on your TV. Be sure they are plugged in and they have a tight connection. Also, be sure they are plugged into the appropriate jacks. They jacks are usually color-coded to match the connector type. Then check to make sure the plug that connects to the back of your console is in the correct port and is snug as well. A loose connection anywhere will prevent anything from coming up, the PS2 was infamous for that.
Aside from issues with A/V, be sure your TV is on and tuned to the correct source. If your PS2 plugs into an RF switch which plugs into the coaxial (cable) port on the back of your TV, the channel should match what the RF adapter is set to before turning on the console. If the PS2 is plugged into your TV through the A/V cables (The yellow, white, and red connectors we discussed earlier), make sure your TV is set to the proper source. The source channels could either be labeled "Video 1," "Video 2," or "Video 3," depending on your configuration. Also, the source could also be labeled "Game."
If none of the two solutions above work, then it appears your PS2 has bitten the dust. Best thing to do is give it a nice tombstone with a beautiful eulogy to make even the most battle-hardened tough guys cry like a baby
Plug the power unit into to the back. Plug the AV cable to the back of the TV (match the colors) and the back of the Xbox. You'll either use the red/white/yellow if you have a regular tv, or the red/green/blue if you have an HDTV. Then switch the switch on the AV cable to the right setting (HDMI/HDTV or regular TV). Install the AA alkaline batteries in the controller (or the battery pack if you got the rechargeable battery kit). Plug the power cord into the power unit, then last plug the power cord into the wall. Wait a minute for the power unit to light up and then push the big green Xbox button in the middle of the controller down for three seconds and let it go. It should turn on. If not, find someone local to help you. This is all stuff covered in detail in the owners manual.
