Question about PNY Optima Pro 2GB Secure Digital Memory Card
Even when i slide the tabb to unlock up the camera still says "Memory Card Error" "card is locked"
    Scholar:
  • 85 Answers
The tiny amount that the lock-unlock slider has to move to make it "lock" is very very small. I mean you could not tell if you were looking at it small, but if you try and slide it up you will feel it slide up a tiny tiny bit. The problem is that when you slide the card in the card reader the friction of the slide in makes the tab go down just a little bit. Then you have your lock problem again. I usually make sure the card is in the unlocked position and place a very small amount of super glue behind the tab (if you clump the glue at all it will never fit back in the card reader) and let it dry for several hours (to let the glue cure to maximum strength). Make sure that the card is not in, on or touching anything where the glue is while the glue drys or it will never come out or off of it. If that does not get it to work try to reformat the card in a PC and try it again (this will blank any data on the card be warned).
Posted on Aug 24, 2010
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Memory card error memory card locked even when I unlock memory card. Tried multiple memory cards.
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this (or if this is happening with multiple cards), see this link for additional things that you can try.
Apr 04, 2010 | Canon PowerShot SD1100 IS Digital Camera
MEMORY CARD ERROR, CARD LOCKED BUT IT ISN'T LOCKED HOW CAN I FIX IT
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Apr 02, 2010 | Canon PowerShot A530 Digital Camera
'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Mar 04, 2010 | Canon IXUS 80 IS Digital Camera
"Card Locked" error is false!
Remove card from SD600 camera. Locate sliding switch on side of SD card and move from lock to other (unlocked) position. That ought to do it. Compact flash card is another issue.
Mar 19, 2008 | Canon PowerShot SD600 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Locked memory card
I guess it is a simple switch problem..
try to switching it between lock and unlock many times until it become ok again..
If it will still not unlock itself, try to format it, for some errors to erased and starts a new one.
Jan 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Locked memory card
hi
the unlocking is due to digital camera and not due to card. card do not have any locking feature. checkup on camera password
or alternately ask replacement fm company as this as 5 yrs warranty
Jan 20, 2008 | SanDisk Memory Media
PNY Optima Pro 2GB Secure Digital Memory Card Logo
47 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
