Question about Kenmore Washing Machines
When you turn it on it fills and drains at the same time on the fill cycle. The water level never rises.
  • 5,911 Answers
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">You may have a condition known as "siphoning". This is usually caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain (siphon) as it tries to fill. The following link explains:<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning" target="_blank">http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning</a><br /><br />In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you. </span>
Posted on Aug 24, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
