I have a Mitsubishi VS-50805 -- worked perfectly well until yesterday. The set will not stay on - most times only stays on for a couple of seconds. I perforned your suggested self-test - and it is returning a 1,2 code. Thank you for any insight.
  • revandenh Aug 26, 2010
    I am not a TV repairman - have no idea what you typed...
  • 5,138 Answers
CK power supply board for bad capacitors they will be vented,swollen or puffed up on Top 1000uf 16v 220uf 10v 3300uf 10v 330uf 10v
Posted on Aug 24, 2010
  • ladywinn
    ladywinn Aug 27, 2010
    Sorry I was thinking your set was DLP ,I ran your model number it shows Projection ,cause of power failure STK ICs big black ICs with part number on them STK392-570 Mats Electronics has them 1-800-628-1118 Also CK pico fuses you could have one or more open
My vs-50805 turns off when it wants for as long as it wants ? How do I fix it ?
In general two possible reasons--sets of this age often develop bad solder connections on the boards--normal with age, heat and expansion and contraction of the the boards.
You can also have a issue where some Glycol has leaked from one of the tubes onto the circuit boards under them--I can tell you where to look and what to look for if you do not know.
Jun 15, 2012 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50805 Service Mode
Sounds like you gotta call that guy back or report him for damaging your set.
Sep 13, 2006 | Mitsubishi VS-50805 50" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
