Question about Kenmore Elite 45986 Front Load Washer
Washer displays f35 and sud - Kenmore Elite 45986 Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
  • 1891 Answers
SOURCE: message sud and f35 causing washer to stop washing
don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
Posted on Dec 17, 2009
  • 1382 Answers
SOURCE: error code F35 and SUD
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 12, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle
Posted on Sep 30, 2010
Testimonial: "Fantastic. Like the subtle hint;)... and well deserved."
Washer displays F35
F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle. If the tub is empty and you do not see any suds please continue with the following trouble shooting tips. A loose wire harness connection could be causing this problem if there is no water or suds in the tub.
I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced.
You can order a new analog water level pressure sensor from the Sears PartsDirect website.
Hope this helps.
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is vibrating badly. it shows a cod f35
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle.
Jan 10, 2011 | Kenmore Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
