Question about Dell 3110cn Laser Printer
Dell 3110 making clicking noise while it prints and is now printing light on the right side?
    Novelist:
  • 217 Answers
You don't say if this is just 1 of the cartridges or all of them, but it's probably just 1, and it is probably a fault inside a cartridge you have replaced recently.
The Dell 3110 cartridge is more complex than many others, and has a Developer Powder (which is magnetic) and the Toner (which is not magnetic). There are paddles and augers inside the catridge that mix the toner and developer, and then move it along the section of the cartridge which feeds the mgnetic roller (which in turn makes the toner available to the drum. If one of these augers becomes dislodged from either it's drive gear, or the locating bush at the opposite end to the gear, the auger either does not turn at all, or moves eccentrically. This results in the mixed developer and toner not beng cycled properly, and wil result in toner 'starvation' or alternately developer/toner overload. Both of these will start at one end of the cartridge and 'progress' along it.
Developer/Toner starvation results in light print.
Overload creates very dense print, and eventually the developer/toner is spewed out of the cartridge, as it just can't cope with the volume that isn't being moved around properly.
Bit of a long winded explanation, but basically its a faulty cartridge, replace it and all should be well.
Posted on Sep 28, 2010
My Dell 3110 driver won't give me the option to print double sided documents
Assuming your printer DOES HAVE a duplexer fitted, you need to use the option in the printer driver to 'get information from printer' - this will update the available options as far as the driver is concerned.
May 13, 2014 | Dell 3110cn Laser Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
I have a dell 926 printer. When I print out e-mails, it will cut off the printing on the right side. Tom
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Dell 926 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Good Luck!!!!!
Sep 24, 2011 | Lexmark X83 All-In-One InkJet Printer
How to enable 2 side print on dell w5300?
Open printers and faxes window, start -> control panel-> printers and faxes.
Right-click on W5300 printer icon and select "properties".
Click on device settings tab.
Click the plus sign (+ ) next to Installable Options to expand the list.
Click Duplex Unit (for two-sided printing) , and then select Installed from the drop-down list.
Click Apply , and then click OK .
Open preferences and under duplex or two-sided printing select-> automatic from drop-down.Click on Apply and Ok.
Then try to print, hope it will work.
May 26, 2010 | Dell W5300N Laser Printer
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
Printing noises - no ink transferring
Sounds like you may need to replace the developer drive assembly. This is the motor and gear assy that drive the color developers. it is located on the right side middle, 3 screws hold it in place. be careful when replacing to not over tightened screws.
Apr 09, 2009 | Dell 5100cn Laser Printer
Printing fonts
you'll need the fonts..go to support.dell.com and see what they can offer.
Aug 20, 2008 | Dell 3110cn Laser Printer
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Dell 3110cn Laser Printer Logo
213 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
