Question about Zanussi TC7114W Electric Dryer
Tumble dryer blowing cold air and not drying.?
  • Zanussi Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
My Bosch Exxcel tumble dryer will only blow cold air
the heater element is toasted,but it's not hard to change and not $$$
Mar 28, 2010 | Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Thermal fuse blows Before this happened heat element went and dryeer would blow cold and not shut off until timer was manually turned off. Replaced all parts except timer. dryer worked for ten minutes and...
If you are referring to the thermal fuse on the tumble drier, my thoughts are that the airflow is being restricted.Cool air is meant to flow in the back air vent which cools the components. This causes air convection and allows the clothes to dry evenly. No airflow makes everything overheat and the first item to normally break is the overtemp. thermal fuse.Go from there.
Sep 23, 2009 | Dryers
My tumble dryer is spinning and everything but my clothes are coming out cold and half dry, how can i solve this?
Clean the vent and make sure you have good air flow to the outside . You can disconnect the vent from the dryer and dry a load of clothes . Comes out dry , vent is the problem .
Jul 30, 2009 | Dryers
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
Zanussi TC7114W Electric Dryer Logo
115 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
