A/c comes on and works fine for about thirty mins then outside fan cuts off and you have to eighter turn off the mains or turn thermostat up to cut off compressor you can not turn thermostat to off and get compressor to turn off
  • ncjdog Jun 02, 2008
    turns out the problem was the circuit board it was calling for the unit to go into defrost mode thanks for the attempt to help
    Genius:
  • 1,073 Answers
Check the compressor relay for sticking some bard units if it is a package unit were bad for this
Posted on May 08, 2008
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
Fan on outside unit cuts off for an hour or so while unit should
Hello Rett Check the fan selector switch setting on the thermostat.It should be set to AUTO position instead of ON.
Jul 15, 2010 | Heating & Cooling
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
95 2L 8V eng code ADY
Just leave the jumper on the switch, it will not hurt for the fan to run continuous. just be sure fan shuts down when the ignition switch is turned off.
May 13, 2017 | 1997 Volkswagen GTI
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Heating & Cooling Logo
259 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
