Contributor
- Posted on Nov 29, 2012
Re: mouse touchpad, keyboard, and usb drives will not...
- Some computers have a touchpad disable and enable hot key, refer to Dell Knowledge Base article "Disabling or Enabling the Touchpad Using the Hot Key" to see if your computer has this hot key and how to use it.
(When your computer does not have the hot key or the hot key did not correct the issue proceed to the next step.)
- Turn off the computer (when the touchpad does not respond hold the power button down for up to 15 seconds to turn off the computer).
- Unplug everything except the power cord, including the following:
- Speakers
- Printers
- Scanners
- USB devices
- Personal Digital Assistants (PDAs)
- USB flash drive or other external storage devices
- External Monitor
- External Keyboard
- External Mouse
- If your computer is attached to a docking station, undock it.
- Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
- Turn the computer back on and retest the touchpad.
- When the touchpad still does not work correctly proceed to step 6.
- When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
- Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
Note:
The touchpad drivers are located in the Input section, listed as Dell Touchpad / Pointing Stick, Alps - Driver or Synaptics - Driver.
- Some newer computers have added gesture features to the touchpad hardware and drivers. A few of these features are two or three finger scrolling, pinch zoom, circle zoom, rotate and swiping. These new features may be the reason for the erratic cursor movement since most are turned on by default. You can disable or modify the way the features work in the touchpad driver properties.
To get to the touchpad properties, perform these steps:
(Refer to the Table of Contents for help determining which Operating System installed on this computer.)
- For Windows 7.
- Click Start.
- Click Control Panel.
- Using the drop-down menu next to View by: in the upper-right corner, select Large Icons.
- Click Mouse.
- Click the Dell Touchpad or Device Settings tab.
- When the Dell Touchpad tab option showed.
- Click on the picture of the touchpad.
- Click Gestures Settings (depending on your computer there may not be a gestures option).
- After changing the options click OK.
- When the Device Settings tab option showed.
- Click the <+> next to open the options you want to change.
- For Windows Vista.
- Click Start.
- Click Mouse.
- For Windows XP.
- Click Start.
- Click Switch to Classic View when available in the upper-left corner.
- Click Mouse.
- Refer to the Microsoft Knowledge Base article, Mouse, touchpad, and keyboard problems in Windows.
After following the preceding steps and the touchpad still does not work, Contact Technical Support.
Mij mouse.. i think it's calles a touchpad?? is not working anymore. It won't do anything, i can't even see my mouse
