Question about Maytag MAH8700A Front Load Washer
What is the error code dS for Neptune Maytag Washer MAH8700AWW?
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
Posted on Oct 24, 2010
  • bryan955555 Oct 24, 2010
    Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine (Maytag Washer Neptune, Model No. MAH8700AWW) is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
  • bunyuk Mar 07, 2011
    The 3E error code is listed in the troubleshooting section of Technical Information booklet 16025939. Mine was attached to the back of the washer.
2 Suggested Answers
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
Jan 19, 2010 | Maytag Neptune Washer
Maytag Front load washerMAH8700AWW.
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
Dec 12, 2009 | Maytag Neptune Washer
Jun 14, 2008 | Maytag MAH8700A Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Maytag MAH8700A Front Load Washer Logo
949 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
