Question about Whirlpool Dryers
My dryer will not heat. was working fine but i moved and had to rewire a new cord on then when complete it will turn on but no heat. Is there a chance the thermal fuse needs replaced?
  • 5,911 Answers
Verify your voltage at the wall receptacle before assuming you have a dryer problem. You should be reading 220-240VAC across the two HOT (left and right) terminals. If the voltage is not correct, you may have a breaker tripped somewhere. Most homes utilize a single dedicated 220VAC breaker for the dryer circuit. However, some older homes, may use two 120VAC breakers. So, if you are missing half your voltage, you may have a breaker tripped, or a bad receptacle.<br /> <br /> If the voltage IS correct, you may not have your power cord installed correctly. Since you mentioned you changed the power cord, you may want to go back and verify how you have it installed. The following link explains how to properly install an appliance cord to your dryer:<br /> <br /> <a rel='nofollow' href="http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord">http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord</a><br /> <br /> <br /> Make sure you have the wires correctly terminated at the terminal block in the back of the dryer.<br /> <br /> <br /> If the power cord is installed correctly, and the voltage at the receptacle is correct, UNPLUG the dryer and check the continuity of the power cord. Perform a resistance check from end to end to ensure the cord isn't broken.<br /> <br /> NOTE: The reason a dryer will still run with half the input voltage, but won't heat, is because the drive motor only uses 110-120VAC to run. This voltage is tapped off the source voltage. The heating circuits, however, require the full 220 service to work.<br /> <br /> If you have any questions about these procedues, please post back with your MODEL NUMBER and let me know. I hope you find this helpful.
Posted on Aug 24, 2010
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
My electric dryer was working fine...I disconnected it and moved it to my new location and had to use a different electric wire and now it works, but with no heat...
You may have connected the power cord wrong. Since you had to use a different cord, you may want to verify if you have it connected correctly. The following link explains how to properly wire an appliance cord to an electric dryer:
If you verify the power cord is connected correctly, and are still experiencing heat related problems, please post back with your MODEL NUMBER so I can determine how your dryer is configured. I hope this helps you.
May 20, 2010 | Dryers
My dryer is not producing heat after recently moving. Can anyone help us? :-)
I am going to assume it is an electic dryer and not a gas dryer, and that the cord hasn't been removed or replaced since moving. Since it was working before moving into a new location, I would check the 220 v outlet. If one leg is dead (or very low), the dryer controls could still work but not have enough juice to run the heat. The first thing to do is to go to the breaker box and turn the dryer breaker off. Then turn it back on. I have seen it where breakers only half-blow...just enough to kill the one leg that pulled the high amps...the heater leg. Even if it doesn't look blown, it is a cheap test..and cheaper fix if that works. If not, then I would bet on a problem in the outlet itself. If you are comfortable with a meter, you can check that. A dead or low leg at the outlet can cause the problem you are having.
If the cord was replaced, make sure the cord is attached correctly and the lugs are tight.
Mar 28, 2010 | Dryers
Recently moved..stopped working after the move
your problem may be in the voltage that the dryer works on. If the cord is fine then I would check to see what voltage that may be supplied tot he dryer and if the dryer can operate on the voltage being supplied.
Dave
Jan 25, 2010 | Frigidaire Dryers
Dryer won't turn on, outlet works, cord works, but nothing works!
Read through the following link and make sure you rewired the dryer correctly:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, please let me know. I hope you find this information helpful.
May 12, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
