Question about Lexmark X5650 ALL-IN-ONE PRINTER
I just set up a new X5650 printer, and after a couple of print jobs, the printer says black and color ink low. I changed to brand new cartridges, and it still says the same thing. What should I do?
  • LXK Chris
    LXK Chris Aug 24, 2010
    Great job on trying on some new cartridges. Try to do Clean Cartridges on the printer. If problem continues, I suggest you contact Lexmark technical support to further investigate the problem.
  • Steve Brooks
    Steve Brooks Mar 28, 2013
    throw the Lexmark in the trash..and never, never, never buy any Lexmark products again..their running a cartridge scam..they quit before they run out of ink and force you to buy new cartridges
    Brigadier General:
  • 10,406 Answers
Some printer-vendors sell "half-full" ink-cartridges, to get you to _sooner_ buy replacement ink-cartridges.
Also, some printers need to be "told" (via software) that the ink-cartridge has either been replaced or refilled. Your printer could be one of those printers.
Posted on Aug 24, 2010
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Replaced both cartridges for my Lexmark x5650, but it still gives me ink levels of the lather cartridges. I have unplugged, reinstalled the cartridges, cleaned the cartridges, cleaned the heads, checked...
Make sure they are seated ok. To reset that printer you should unplug it from the wall for a couple of minutes. Make sure you can move the carriage by hand.
You should remove the ink cartirdges and power it off by unplugging then plug it in and turn it on and see if it asks for ink cartridges. Then you put them in and try again.
Oct 01, 2013 | Lexmark X2670 All-In-One Printer
How can I install black cartridge only without printer stopping me from printing
The Lexmark X5650 printer requires both the black and color cartridges to be inserted in the printer to continue printing. Both cartridges must have ink in them and not empty.
Sep 03, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Lexmark X5650 ALL-IN-ONE PRINTER Logo
146 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
