Question about Epson Stylus CX3200 All-In-One InkJet Printer
Started to copie then went wrong on second sheet error light came on all time cant do any thing with printer can you sugest what to do thank you
  • rjstatham Aug 25, 2010
    will try but must write your solution thank you
  • 6,993 Answers
Follow the steps below in order to solve the problem:
1. Download from the site as recommended SSC Service Utility http://inkjetprinterhelp.us/
2. When taking off the scanner unit there is a smallish cover on the left hand side of the printer at the back; remove this and disconnect two ribbon cables, two cables with push pin conectors and a spade connector, 5 altogether.
3. Two screws hold down the hinges of the scanner unit remove and store carefully. Lift off scanner unit.
4. Take out four screws holing printer body on, long magnetic philips screwdriver needed. store screws lift off cover.
5. At back of printer are the three waste ink pads; use a spade end screw driver to lift out one at a time. They are about 5cm x 9cm and the bottom one is slightly different shape to other two.
6. Rinse them thoroughly with water and then squeeze out and dry. I used kitchen roll and then hair dryer.
7. Replace one at a time tucking in corner bits with screwdriver.
8. Replace body, scanner unit, wires and cover.
9. Connect up printer and switch on. Error light will come on again; don't dispair, this is what fooled me. Open SSC utility on desktop and then close; icon appears in lower right screen on application bar like printer icon. Right click and pop up menu appears; left click on "Protection Counter" and then "Reset Protection Counter".
10. Turn off printer and then switch back on again. Error light should go out and you can carry on.
I hope the above helps to solve your problem.
Good luck.
Posted on Aug 24, 2010
Where can i get the tech data sheet to get error codes and fix whatever is wrong, cant afford to pay some technician.
You did not post any information on who makes it BUT the manufacturers put a tech sheet inside the unit. If it is a front loading machine, the tech sheet is behind the panel under the door and the panel is secured with screws near the bottom.
Jan 09, 2015 | Washing Machines
Download Cannon resetter for error code 5B00 model MX416
FIRST STEP : ENTER SERVICE MODE
<Service mode operation procedures>
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the
buttons). The COPY button lights in blue to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each
time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in blue, starting
with Alarm LED.)
4) When the COPY button lights in blue, press the Stop/Reset button 4 TIMES
SECOND STEP : DOWNLOAD THE FOLLOWING PROGRAM.
www.4shared.com/get/zc4OMn2_/Service_tool_v3400.html.
1. Run the program
2. Set the region according to your location, then klik set
3. klik set on the Ink Absorber Counter
4. Prepapre 1 sheet of paper.
THIRD STEP : TURN OFF YOUR PRINTER AND THEN TURN ON AGAIN.
FINISH
Sep 06, 2012 | Canon Office Equipment & Supplies
Hi everybody, I have got a canon Pixma MP 130 printer and the problem is error 6000. during printing process the printer broke down and did strange nose! Can someone help me? Would be more than happy to...
Hi, I had the same problem and went searching - all the feedback suggested that something may be stuck of blocking the paper path. Took the tray out, checked underneath etc - and yes - the problem was a couple of sheets of paper stuck inside. Was able to retrieve these by accessing them from the rear of the printer - and when plugged back in it started up OK!
I believe the cause here was that a print job was sent to the printer while it was also being used to copy stuff - though i cant be sure of this. Either way, it was a blockage that cased the problem.
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board
Thanks for using fixya...
And please don't forget to rate me...thanks.
Oct 25, 2010 | Canon PIXMA MP130 All-In-One InkJet...
1. Our copier doesn't work 2. Our printer doesn't work.
It sounds like you have some clogged nozzles. If you have not tried using the cleaning utility, try this first. If you are using aftermarket or refilled ink cartridges and the nozzle cleaning process does not clear the problem, I would put in new OEM cartridges (I know that they are expensive) and clear the nozzles using the cleaning process at least 3x. This should clear the problem. Be careful using aftermarket or refilled cartridges since they often do not meet the manufacturer's specifications and often clog the nozzles.
Let me know if this clears the problem otherwise we can try some other things. Thanks.
Apr 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Frigidaire Model FTF21400ES0 Will not start just blinks
The control board will store error codes in memory. If you can get this unit in a test mode, you will be able to retrieve those error codes. As you hold in both the start & pause/cancel together the error code will be displayed.
You will need to count the flashing lights to read the error code. As you hold in the start & pause/cancel pads together, count how many times the row of lights flash on the far right hand side. This is the first digit. Now, as your still holding in the start & pause/cancel pads count how many times the start light flashes, this will be the second digit of the error code. Take note; all the lights flash at the same time so be sure to take separate readings
Without knowing correct Error code it is useless to waste money in replacing control board . You need to get the error code to diagnosis the problem correctly .
Jan 12, 2009 | Washing Machines
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Jul 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Slower printing speed
Multiple sheet feeding in any printer can mean many things. Paper roller blockages and jams, wrong paper for printer, too much paper in. Make sure you check right down the back and inside the unit for anh small blocks. This can then cause errors in the printer itself. As it is now printing but slow, the paer issue could be resoved but you may now have driver errors or pc issues. Are you getting any flashing LED lights. Have you checked to see if device is showing errors or functioning correctly. Go to start menu, control panel, performance/main, system, devices, scroll down to your printer, are there any yellow exclamations? Does it say it is working ok?
Aug 10, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
296 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
