Question about Kenmore 24 in. 16332 / 16334 / 16339 Free-standing Dishwasher
Have a Kenmore Freestanding Dishwasher that was working when hooked up to the sink. When we plumbed it in and connected the electrical directly, we now get an "F4" flashing on the panel with a beeping noise and the pump sounds like it wants to drain but just get a sucking noise. I've tried putting water in it to prime the pump, but still doesn't want to work. Do the codes mean anything, or point to a specific part?
catriver
  • 878 Answers
SOURCE: Dishwasher fills w/ water, does not wash, but does drain.
Joel, it's hard to tell whats going on here without the full model number. The number you posted should start with a 665, 363,587 or 464.  Here is a couple of things to look for.  It sounds like you have a seperate drain pump. Remove the bottom toe panel and hopefully there will be a tech sheet behind it.  Check the harness to the motor itself.  You want to verify that there is 120V going to it when the wash motor should be running. If you hear the motor humming and kicking out on the overload, then we can assume you have something stuck in the impeller or the motor is bad itself. The tech sheet will give you a diagram for the hot and nuetral.  Check the float switch inside the tub, it should move freely up and down. This is a safety device to insure the dishwasher does not overfill.  If this is a 665,  there will be a start capacitor on the left side of the wash motor.  If one of the wires came off the cap,  the motor won't run.  Regarding the door switches,  if you have 120V going to the motor during the wash cycle, you can assume the door switches are o.k.   Hope this gets you started in the right direction...Catriver.
Posted on Oct 14, 2007
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
SOURCE: Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Posted on Aug 22, 2008
  • 9 Answers
SOURCE: kenmore 655 ultra wash built in dishwasher
Possible problem is that the chopper/cutter filter is plugged. This prevents water circulation and therefor no water is available for cleaning.
Solution:
Remove the dish baskets.
Remove the bottom cleaning arm - Rotate the centre post and the arm can then be removed.
Remove the conduit that feeds the upper arm(s) - Remove screws, one at the back and one at the top. Rotate the whole assembly 45 deg right and lift off of the centre post.
Remove 4 screws in the plastic assembly and lift it off of the centre.
Remove 1 screw at left front (Under assembly just removed). Lift off the plastic cap which covers the cutter/chopper. Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. Thoroughly clean the filter disc - a knife will be req'd to scrape in clean.
Reassemble in reverse to the disassembly steps.
Posted on Jan 05, 2009
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
    if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
    If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
    Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
    DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
    Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
    Good luck hope this helped you some
    Dave
    Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
    A portable dishwasher doesn't hook up to sink
    take the airator off your faucet and take it and the fitting to the dish washer to a plumbing supply house, look one up in the yellow pages, set them on the counter and they will do the rest
    Dec 25, 2009 | Kenmore Dishwashers
    Dishwasher drain hose.
    Its ok to hook to the sink drain but an air gap should be inline with it to prevent sink water from backing into the dishwasher.
    Feb 12, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
    Hose hookups
    the smaller hose should be 3/8" is the water feed the larger hose is the discharge. you can open the front panel (2 torks screws) and you will see the water inlet valve in the left towards the center the electrial box is on the far right ten determine which hose you have for the fill under the sink...You will need a disposal or a tee off the plumbing to connect the discharge hose and a 3/8" off the HOT side of you sink plumbing to connect it Let me know what you find
    Jan 28, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    How to install diswasher
    To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
    #1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
    #2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
    #3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
    #4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
    x 3/8" compression ell at the dishwasher.
    #5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
    #6 Install a 6' pigtail power cord to the power box under your dishwasher.
    #7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
    #8 Attach the water line to the open connection on the double stop.
    #9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
    #11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
    #12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
    #13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
    #14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
    #15 Attach the bottom kick panels
    You are done.
    If you have any questions, please let me know.
    Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Installing my built-in dishwasher
    the plastic drain hose goes either to the sink drain plumbing either to the pvc pipe or the disposer. there is a electrical junction box on the right side where you hard wire the unit in there is the inlet valve on the Left side of the lower axcess panels where you hook the water supply
    Oct 01, 2007 | Admiral 24 in. DWUA800AA Built-in...
    Kenmore 24 in. 16332 / 16334 / 16339 Free-standing Dishwasher Logo
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
