Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My refrigerator is too cold even though it is on the lowest setting
  • 4,793 Answers
Check for an air leak on the seals first, then get back.....
Posted on Aug 24, 2010
Refrigerator runs too cold even on lowest setting
they had door closer problems make sure door it fully closed and not staying open just slitely and letting air out, hing closer is plactic pieces on ref door bottom and piece on hing itself.
for parts go to (coolblueworld.com) THIS IS FISHER PAYKEL WED SIGHT.
May 02, 2014 | Fisher and Paykel Active Smart E522B...
Frc150ff fridge is too cold
You know that the lowest setting is the coldest .
Set it to 35 refrigerator, 6 degree freezer and see what haopen
May 27, 2017 | Frigidaire FRC150FFS
Refrigerator side is too cold even with thermostat on lowest settings
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Fridge is too cold even at lowest setting and freezing drinks.
The thermostat sounds like it is out of calibration and stuck closed. A good replacement would be a Ranco A12-1560 mounted in the evaporator (cold) coil.
Nov 07, 2009 | True TBB-3G-S Commercial Refrigerator
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerator kenmore
fresh food thermister should be checked. also the damper assembly that regulates cold air from freezer to fresh food side.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Propane refrigerator is too cold
You have a defective thermostat. Change it.
Nov 18, 2007 | Danby DPAC10061 Air Conditioner
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
24 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
