Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer loads with water but will not start to agitate --seems to be a switch in the cover---what do I need to do re the switch
  • 5,911 Answers
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span>The symptoms you describe are common for a lid switch malfunction.</span></span></span></div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span><span>If the model nuber you posted this question under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3557193-replacing_a_lid_switch" target="_blank">http://www.fixya.com/support/r3557193-replacing_a_lid_switch</a><br /><br /><br /><br />NOTE: If the washer is still full of water, you do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.<br /><br /><br />Replacement parts (if required) can be purchased at any of the following web sites:<br /><br />searspartsdirect.com<br />pcappliancerepair.com<br />appliancepartspros.com<br />repairclinic.com<br /><br /><br /></span></span>The part number for a replacement lid switch for this model washer is 3949247. The lid strike is 358684. These parts are listed as items 11 and 20, respectively, under the "Top and Cabinet" parts section.<br /><span></span></span></div> <div class="solution-text"><span><span></span></span> </div> <div class="solution-text"><span><span><span>For future reference : If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. <br /><br />Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.</span></span></span> </div>
Posted on Aug 24, 2010
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Washer overflows as it agitate
The problem is going to be that the water inlet valve is sticking open and thusly needs to be replaced. It could have been a bad water level switch but since its does agitate that tells me that the water level switch is good or it would not agitate and fill at the same time yet if it were the problem it would fill and never start agitating. So that makes it for sure just the water inlet valve thats the problem.
GENE
Oct 09, 2011 | Admiral AW22 Top Load Washer
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
The washer turns on, fills with water and starts to agitate...then never stops. It just keeps agitating till I turn off switch. The switch/dial never seems to move.
Its seems to be the complaint of the board. You can locate it beneath the unit but those things are so complicated and can be repaired only by a professional. Sometimes it may be needed to replace it, but in that case, it will be expensive.
Aug 20, 2010 | Frigidaire FEX831CS Top Load Stacked...
Starts to agitate as soon as cover closes, will not spin
Bad timer. It has welded points making it imposiable to change anything on time. Needs replaced.
Please rate solution
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 80 series washer
you removed the cover ??? cool your looking right at the pump assy remove the 2 clips and release the pump from the motor assy(dont remove the clamps) thers enough room to hold it of to the side, after doin this try starting the machine(it should at least agitate with cover removed.)if it does agitate with no problem stop the machine and reinstall the pump(you may have to manually turn motor shft to correctly align pump. try it again.if it doesnt work now then theres something stuck in the pump(baby sock, bra underwire).
Feb 24, 2008 | Washing Machines
Overflowing and smell
needs a new pressure switch located in control panel are the small rubber hose going from the switch to the tub has a pin hole in it
Nov 29, 2007 | Frigidaire GLWS1233A Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
