Question about HP Photosmart 3210 All-In-One InkJet Printer
How do you clean print head for an HP 3210 all in one
myob247
  • 1342 Answers
SOURCE: HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
Posted on Apr 27, 2008
mgdev24
  • 59 Answers
SOURCE: hp 3210 photosmart all-in-one printer
check the catridge number size if is the same with the one that come with your printer if is not the same number then the one you buy is not conpactable with your printer so it can work unless you get the actual number of the one that come with the printer. but if the size is correct then check the fixing again and fixe it properly. or you check the printer software uninstall it then reinstall it back, also, your can check the container the ink store in when the printer finish printing inside the printer in some cases if their is alot of ink setle in that container the printer will not ready so what you do is that there is a fome in it that **** the ink bring it out and clean it very well then put it back.
Posted on Nov 17, 2008
  • 8 Answers
SOURCE: HP Photosmart 3210.
Look at "black ink problem" higher in these posts. 9 people offering solutions.
You may need to force the blockage out of the black ink feeder system.
This is a serious design fault which HP will not acknowledge.
Posted on Jan 07, 2009
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
  • 708 Answers
SOURCE: My HP 3210 won't print with vista. Are there any
HP.com should have them. just go to their website adn download the latest driver
Posted on Sep 29, 2009
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
Changed black ink but it still prints very very lite and only part of the document.
Hi
Try to make print nozzle for 2-3 times to clean the print head.
If not, adjust the print quality from text to photo.
Regards.
Feb 19, 2011 | HP Photosmart 3210 Printer
I have a HP 3210 All-in-one printer that I am having problems with. Whenever I print a picture or anything is certain colors I get stripes. It works fine in black and white. I have replaced all of the ink...
the nozzles are clogged most likely. try to clean it by using the software provided. another thing is try to align the print heads. that's also included in the software for the printer.
Jun 25, 2010 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 printer is not printing black color
must be dryed ink on ink cartdrige, or dirty print-head (ink cartdrige) conntector.
try these :
To clean the print head from the control panel
1. Load letter or A4 unused plain white paper into the main tray.
2. Press Setup.
3. Press 5, then press 2.
This displays the Tools menu and then selects Clean Printhead.
or
To clean the ink cartridge contacts
1. Unplug the power cord from the back of the HP All-in-One.
2. Lift the ink cartridge access door.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
4. Inspect the ink cartridge contacts for ink and debris buildup.
5. Dip a clean foam rubber swab or lint-free cloth into distilled water, and squeeze any excess water from it.
6. Clean only the copper-colored contacts.
7. Place the ink cartridge back into the empty slot and press down on the gray latch until it clicks into place.
8. Repeat if necessary for the other ink cartridges.
9. Gently close the ink cartridge access door and plug the power cord into the back of the HP All-in-One.
These steps is printer manual on pag 99 and 100
Jan 15, 2010 | HP Photosmart 3210 Printer
HP3210 -is not printing the full document only the heading
Go into "Printers and faxes" under "Control Panel"
Right Click on the Printer and select "Properties"
Look for a "maintenance" or "Tools" option then Try
"Cleaning" or "Deep Cleaning"
Jan 12, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP 3210 not printing black ink
Look at the posts on "black ink problem" later on this site (mostly Dec).
This appears to be a very common issue with this model and results from a serious design error.
You may need to force the blockage out of the black ink feeder system, a messy process.
The 9 offers on "black ink problem" give various suggestions: try the top one.
Jul 06, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
316 people viewed this question
Seeker5211
Seeker5211
